5402 and rf feeds
  • nigela
    • Mar 2012
    • 49
    5402 and rf feeds
    I have just purchasesd a5402 to replace my old sky box. One of the main reasons I chose this box was the fr outputs so I could send the output to other rooms. Unfortunately the quality of the picture sent to the other room is appalling. Any suggestions of what I might be doing wrong? (the picture in the main room is excellent).
  • Manic01
    • 5117
    Change rf output channel on receiver.
    I have tm5402 and pic is good from rf out.
    • nigela
      • Mar 2012
      • 49
      What channel is yours set to and how do you change this?
      • Manic01
        • 5117
        Menu - System settings -av settings- select rf channel-exit and save.
        Keep changing till you get good one.
        Most TM set as default to 40
        • nigela
          • Mar 2012
          • 49
          Yes mine was set to 40. I have tried changing to all the others and I get nothing - just blue screen - in the other room. Any other suggestions?
          • dick b
            • Jun 2009
            • 2462
            once you have changed the output on the technomate you will have to scan for it on the TV
            • nigela
              • Mar 2012
              • 49
              I didn't do that - any suggestions on which rf channel numbers to start with first?
              • Carew6
                • Mar 2010
                • 212
                It depends what RF channels that your terrestrial transmitter is using, but if you are not using a VCR then CH36 should be clear, otherwise start at CH21 and work your way up remembering to retune the TV each time.
                • happy_highlander
                  • Aug 2010
                  • 3535
                  Took a quick pic of the rf output I get from my tm5402 on channel 60 granted it's not hd quality but I've never seen an rf that is.uploadfromtaptalk1339696885234.jpg
                  • nigela
                    • Mar 2012
                    • 49
                    I am not getting a lot of luck - I have done about 15 channels and none of them have picked up a signal at all. Channel 40 is the only one at the moment and the quality is awful. Will keep going.
                    • Carew6
                      • Mar 2010
                      • 212
                      Your old Skybox would probably have been set at Ch68, so try that if you had the Sky connected by RF lead.
                      • nigela
                        • Mar 2012
                        • 49
                        I tried that one - got nothing. Is it normal on most channels to get nothing?
                        • Carew6
                          • Mar 2010
                          • 212
                          Can you disconnect the HDMI lead from the 5402 temporarily to see if that is causing interference as some are known to do this.
                          • nigela
                            • Mar 2012
                            • 49
                            That hasn't help - I have plugged in the scart instead of hdmi but no difference.
                            • Carew6
                              • Mar 2010
                              • 212
                              Have you got a different RF lead that you could try ?
