Does anyone know the easiest or best way to add the itv & bbc regional channels to the channel list i've downloaded from here because the channel list is good with all favourites sorted as i like but i do not want bbc1 + bbchd & ITV1 + ITV1HD from another region as the news is irrelivent to me
adding regional channels TM-5402
Tags: None
add them by doing a manual channel scan, but find the frequencies from sat kingz.
Im in yorkshire that's what ive done for my Blade box like BBC 1 Yorkshire and Lincs and Itv 1 Yorkshire West is more relevant to me im sure yours can be done in the same way and then add them to you fav catagories
Hillsborough 15th of April 198996
thanks for the replies , ive got CTechEditorStudio & cannot find from my channel list itv south west & bbchd/itv hd don't state thier regionsComment
You won't have them already on the list especially if it's the one I uploaded. Heres what to do......open clarke tech and click the file tab the click import this will bring up a huge list, you want to select "web" then ok. This will generate a full channel list from king of sat. You then open the list you have in another page do you have two lists open find the regional channel you want from the web list and right click it then copy, open the other list and right click on the regional channel you are moving select paste from clipboard then delete the region you don't want as both regions will be together, don't forget you now need to add that new channel to favourites, repeat these steps for all regions you want to change. Then save your list, add it to usb and copy it to stbComment
