Hi, just a quick question please, I have a TM5402 HD and last night I have tried to record onto my usb pen drive a film that was on a scrumbled channel (but visible via cs and softcams files), but when I have checked the film there is a file long 2 hours but is all blank....So my question is can I record on a usb pen drive a scrumbled channel? Second, I have check the performance of my usb drive(it is a sandisk 8GB) with the feature of speed check on the menu of my box, and it says low performance or something like that.... What could it be?many thank for your help
tm5402 record problem
I am sorry to be a pain but I tried again and same problem... 2 hours file blank....it seems like when I set up the timer my box is not able to record a 2 hours film onto my usb pen. Instead there is no problem when I record by pressing the record button. Any idea?Comment
get a better performer usb powert HDD around 320-500 gb or
an iomega 1TB is what i use on my tm's all the time with little problems.
did you format the usb pen drive in the disk manager menu of the tm ?Everything discussed on this forum is for experimental and educational purposes only. Use the information at your own risk.Comment
try formatting it in the tm this is what i use all the time because when i had the tm 6900 non super i formatted on the p.c. too
and had similair problems but when i formatted it in the tm's disk managers menu it worked fine after that.(fat32)Everything discussed on this forum is for experimental and educational purposes only. Use the information at your own risk.Comment
There are loads of converters that will do this job. Google "convert ts to avi"Comment
i think it's .trp files try this .TRP to .AVI - Convert .TRP Video to .AVI i don't really bother with it but let us know if it works
it's not a free one ,i'll have a look for a free one, try Prime Time FreewareLast edited by thijs; 13 September, 2012, 19:58.Everything discussed on this forum is for experimental and educational purposes only. Use the information at your own risk.Comment
i know this may not be part of the subject, but just wanted to confirm if it is possible to record one channel and watch anotherComment
