tm 6000 channel list
  • benny/9
    • 1964
    this is a tm 6900 HD receiver channel list.
    that has all the channels on all the satellites
    sorted in a good viewing order and will
    save you hours of channel moving and sorting.
    this list has tv chns only no radio chns scaned
    plus there are no favourites set on this list
    and covers the following satellites:--------
    30w-24.5w-15w-12.5w-8w-4w-1w-4.8e-7e-9e-
    13e-16e-19e-23.5e-26e-28e-33e-36e-39e-42e
    depending on your dish size you might not receive
    all the satellites, set your sat list for the sats you can
    get signals from. i use a 36v motor and a v-box with my
    dish, if you follow the following instructions you can use
    this list on your receiver without losing your dish settings
    how to change chn lists [this does'nt factory reset your box]
    leave your dish on any sat your settings will not change
    menu>pin 0000>system settings>ok factory reset>ok
    enter pin 0000 and go to line [3] deleate all channels
    press>ok and yes and save the change
    take the chn file out of the folder ready to transfer to your memory stick.
    then put the memory stick in the usb port on the receiver and
    download the new channel list to the sat box.
    i have also loaded this list on the clarke-tech 5000HD cplus combo this is the same spec as the tm 6900 super i have tested this list on the tm 6900_super model and the
    tm 6900 original model it is'nt tested on the tm 6800
    Please Read Carefully!
  • .: JaCkPoT :.
    Retired Sat TV Addict
    • Aug 2008
    • 5607
    Wicked mate, i will edit this and remove the hd channels so its then compatible with 5000and 1000..is that okay?
    Im sure you posted this before! Or did it go when the forum went down?
    ___________________
    In the good old days, I had
    DM800s HD
    Openbox S10
    TM500
    DM500s
    90cm FortecStar dish
    Maxx 110cm Dish
    Technomate 2300 Motors
    • batman44
      • Mar 2009
      • 276
      Thanks Mate! nice one
      Keep calm carry on.
      • benny/9
        • 1964
        i thought i had but when a posted asked for a tm 6000 chn list
        i could'nt find it,
        • Oily
          • Apr 2009
          • 123
          Cheers
          • .: JaCkPoT :.
            • Aug 2008
            • 5607
            i could'nt find it,
            yeah..i lost over 40 posts when the forum when down so it may have been lost then because im sure i saw this thread before!!
            ___________________
            DM800s HD
            Openbox S10
            TM500
            DM500s
            Maxx 110cm Dish
