how do i get 46e sat into my 5200super the list i have goes 42e then 57e can i get a new list of new sats up there had it about 5/6 years
thanks samsheene
thanks samsheene
press menu,installation,satellite set-up,find a spare slot and rename to azerspace 1 and save. go into the motor setting and put in 046.0 degree,s east and save. in the satellite set up find azerspace 1 and tick next to it to store the position. now send the motor to 46 east via usals/diseqc 1.2.. if you are using 1.2 you will have to add an active transponder in the advanced search menu. 11.014.H.28500 so you can find the satellite if using usals when the motor has stopped just do a blind scan from 10.950 to 11.200 in horizontal only and you should find the 2 active transponders carrying channels on the european beam. you could try a pre-made list if you want or repeat the proceadure yourself and delete unwanted sats/txp,s although its time consuming. you can use NDFedit also if you want to make a list on the pc.regards mdt
