technomate tm500 plus problem
  • funjoe
    • 7
    hi,
    i have a technomate tm500 plus reciever running enigma and on signal loss channel freezes then goes to blackout and does not resume on signal restore without a channel change or reboot, this does not occur on fta channels.
    cant be discussed but this is a major problem for me
    anyone help please
    funjoe
  • sparky stu
    • Oct 2013
    If you are on a none free channel and then change to another none free channel, does it go black then or only on signal loss.
    ie running on s*y sports 1 to s*y sports 2
    • funjoe
      • 7
      hi,
      no it works fine on fta, only occurs on non fta channels , and only on signal loss
      achannel change forward and back will restore or a reboot
      • happy_highlander
        • Aug 2010
        • 3535
        What firmware are you using? ???? The cam is not autostarting after signal loss same as it won't autostart after restarting enigma only instead of full reboot. This problem is usually found if using mgcamd on iq/ur images the latest firmware is by far the worst
        • funjoe
          • 7
          hi,
          thanks for info,
          yes cam does not restart on signal loss but it will restore on channel change,
          probably is firmware though, using cccam
