need help
  • oneil
    • Aug 2009
    • 8
    need help
    need help finding fta files(patch) for my tm 3150d receiver can anyone help me
  • bimbam
    • Aug 2009
    • 29
    hopefully this helps i dont have the box my self but that is the section that has updates for your series box.
    let me know if the link works
    • oneil
      • Aug 2009
      • 8
      thanks hope it works
      • .: JaCkPoT :.
        Retired Sat TV Addict
        • Aug 2008
        • 5607
        make sure you use the specific one for your receiver. If you load the wrong one then your box is dead.
        ___________________
        In the good old days, I had
        DM800s HD
        Openbox S10
        TM500
        DM500s
        90cm FortecStar dish
        Maxx 110cm Dish
        Technomate 2300 Motors
        • oneil
          • Aug 2009
          • 8
          thanks how do i add anew satellite to the tm 3150d
          • dick b
            • Jun 2009
            • 2462
            go into the installation menu then the top line satellite set up.use the left and right arrows to get the sat you want and press save (the yellow button on the remote)
            you can add sats that are not pre-installed by going back to the top line finding either an empty slot or a sat you dont use and press the green button on the remote to re-name it.
            then drop down to the sat degree line and input the correct degrees for your chosen sat. dont forget to press save after all this other wise you will lose the settings.
