technomate 7100 triple tuner
  • dickmyers06
    • Apr 2010
    hi guys did anyone come across this niggle fault if u like
    i own a tm 7100 triple tuner the fault is this recording to internal harddrive im using a seagate 1 tb recording is ok for the first four times then it records blank it shows in the menu that recording has taken place but blank tm sent me software but that only cured the problem for a short time so can anyone help
  • jitkacerv
    • Nov 2011
    Hello I had the same problem. I changed 1 tb for 500 gb and don't have this problem any more.
    • thijs
      • Apr 2010
      • 1096
      i don't have this problem with external hdd's what patch or what firmware are you using and what were you trying to recording it happens to me sometimes when the channel has childlock on it but never with normal channels.i'm using 1tb externalharddrives all the time on my tm7100+6902 now (iomega /prestige at the moment)there is a known problem with the internal hdd in the tm's allright they draw to much energy and stop working proper i used to have one in the beginning but after to much problems i got rid of it ,if you get a housing for your drive with it's own powersuply and plug it in as usb this should sort it.
      Everything discussed on this forum is for experimental and educational purposes only. Use the information at your own risk.
