Epg help
  • mach7
    • May 2010
    • 16
    Epg help
    hi
    i have a tecnom8 tm600 reciever. I am having problems viewing the epg guide. i press epg on the remote , but i can not view all days program listing for any chanel.
    i can only view whats on know and whats on after, ie two listings per channel.
    i am totaly new , was reading on this forum about Weekepg install, will this work i dont want to make things worse on the box,,
    also do i have to install it everyweek to get the latest info ???
    thank you
  • manxspud
    • 1768
    Hi m8 ... you will only get now and next at best with out using a add on such as week epg.
    here is the pdf made by @digi on how to use it ...
    WeekEPG on TM500 600.pdf - 4shared.com - document sharing - download
    @manx
    • eattheliving
      • 331
      @manx
      just done this myself. very easy and yes it works
      • mach7
        • May 2010
        • 16
        hi i have tried this , when i restart , press the yellow button a error appears
        "warning epg data is out-of-date update required for offline mode"
        i have made sure epg storage path is \tmp\
        still no joy
        • eattheliving
          • 331
          still no joy
          i had this to start with. i just updated and it worked fine mate. is your tm600 connected to the net?
          • mach7
            • May 2010
            • 16
            hi
            yes its connected to internet, out of interest how did you update
            • eattheliving
              • 331
              hi
              i believe it told me it was out of date and did i want to update...i clicked ok. then carried on with the install. worked a dream matey
              • mach7
                • May 2010
                • 16
                i dont get this option, also in the guide it said you have to select "hiphop" i am not sure how to do this
                please help
                • eattheliving
                  • 331
                  please help
                  i had to download a new channel list for 28.2e. then i got the option of the hiphop channel in the radio channels.
                  • mach7
                    • May 2010
                    • 16
                    thanks , i managed to get it to work
                    • ToneDeff
                      • Feb 2010
                      • 34
                      just posted an updated config for "WeekEPG"
                      • eattheliving
                        • 331
                        glad u r up and running matey
                        • allnighta
                          • 75
                          just got hold of a tm600 the other day and got it all up to date with latest bouquets and was hoping to get the epg guide working but i defo dont have the hip hop channel
                          does it not transmit any more and can i use a diff radio station?
                          thanxs in advance
                          • hooley
                            • 470
                            Use the music choice radio channel on 28.2
                            • eattheliving
                              • 331
                              or EPG background music
