i have a problem with tm 600 flashing
  • happyman1978
    • Nov 2010
    • 12
    hi to all, i bought tm 600 and i had tm 500 before and i have an idea how to flash using web interface but the tm 600 can't flash, everytime i hold the power button and start the receiver from the back power button it switch on but it says FAIL and it start the channels and i can't see the ip so i can install the image please help me thanks.
  • ITS A SCAM !
    • Oct 2008
    • 1140
    I flash all the tm600's with a USB pen.....Try that method
    • happyman1978
      • Nov 2010
      • 12
      what format should the image be is it img or different.
      • ITS A SCAM !
        • Oct 2008
        • 1140
        Just a normal USB pen will do it.....delete everything on it and copy the image onto it, place into tm600 and away you go
        • happyman1978
          • Nov 2010
          • 12
          is still can't read the urimage.img
          • ITS A SCAM !
            • Oct 2008
            • 1140
            what image is there on it at the moment ?
            can you perform update software via USB with using the remote control ?? Menu / Set up / Expert Set up / Software Update / USB Update
            • happyman1978
              • Nov 2010
              • 12
              no i can't update it at all and whenever i i connect the ethernet it says no internet connection?
              • ITS A SCAM !
                • Oct 2008
                • 1140
                Are you setting it up ok ? you will need to allocate it a static ip
