I've just set up a new 7102 - with A1, A2 and Hotbird running down two cables each passing through a Diseqc. Great pictures and usability but have two big issues with it.
1. I can't record two channels at the same time. As soon as one recording starts (say on Hotbird), I get a blank screen and 'No signal' on any Astra 1 channel. I can switch to Astra 2 (but think this is because if the Diseqc is unpowered, the cable defaults to port which is Astra 2). This is with Tuner setting set to Twin - if I switch it to single, I can't change channel at all unless I stop the recording.
2. The internal HDD continually seems to disconnect itself so no disk found if I try to record. Sticking in a USB memory stick and/or restarting the box sometimes gets it to appear again but it doesn't seem reliable and I'm concerned about unattended recordings actually happening.
Also, minor issue - is there a limit on the number of Favourites in any group? I was entering the main euro channels when pressing the OK button seemed to stop marking hearts. Deleting others seems to re-enable it...
Any advice from those who have a working setup would be most appreciated.
kind regards
kind regards
