technomate 5400 super
  • gothi
    • Jun 2009
    • 14
    hi eveyone just afte a bit of help.I havent done anything with the tm5400 since the premiers went off,how do you load these new phantom patches and soft cams,is bullsat still opening cheers gothi
  • hoggy952
    • 1229
    patching with a usb stick
    1. copy the latest technomate software & latest patch & latest softcam.
    2. transfer Technomate software to receiver. (PIN code 0000) MENU -> USB -> Data Transfer -> select technomate file -> OK -> reboot.
    3. Transfer patch to receiver. MENU -> USB -> Data Transfer -> select patch file -> OK -> reboot.
    4.Transfer softcam to receiver. MENU -> USB -> Data Transfer -> select softcam file -> OK -> reboot.
    5.Peform "Blind Scan" of desired satellite.
    done.
    • mdt
      • 3034
      at the moment there is quite a bit open via patch/softcam if you have access to a motorised dish.
      bulsat=39e
      arqiva=4.8e
      orf=19.2e
      austriasat=19.2e
      tnt=19.2e
      rai=13e
      tvglobo=13e
      mezzo=13e
      sic-int=16e
      about 15 b.i.s.s channels
      n*k/s*t/t*2den and d*1+2 on 4.8e although i cant say if these are incorperated into the latest patches. thanks to phantom and others for keeping the non-lan capable stb,s up to date and giving us free tv , regards mdt
      • Manic01
        • 5117
        Just to add there is no Phanthom , Its all from the koreans as usual.
        • xfx
          phantom patch
          hi does any body no what the latest phantom patch and softcam keys is for 5400 usb super
          • dick b
            • Jun 2009
            • 2462
            you will find the patches at Download center and softcam in the softcam section on this forum
