tm5402hd
  • newts
    • Apr 2011
    • 8
    #16
    get a blade !!!!!! THERE THE BOLOX
    • TcG1
      • 68
      #17
      And also allegedly a clone of the TM5402 ! apparently made in the same place / factory too.
      From what ive seen they are both pretty good as far as they go,hard to compare in many cases.
      • gadgetfiend
        • Aug 2008
        • 355
        #18
        never a clone as it was out well before the 5402 and lots of differences too, technomate are just peeved at its rising popularity as its taking coin away from them.
        • the man
          • 1660
          #19
          Originally posted by thijs
          it's non linux It does cs share client only with an addon
          or cccam. You can record and watch an other channel on the same transponder not any channel.and built in divx player and
          7-epg on 28.2 programe name.
          it has a full working 7 day epg on sky? does it auto update ect?
          • thijs
            • Apr 2010
            • 1096
            #20
            you load the 7-day epg through a radio channel
            so when you switch back to tv channel the epg update stops
            tm is working on something to do this automatic.and like i said
            the 7-day epg is programname only at the moment no full info
            Everything discussed on this forum is for experimental and educational purposes only. Use the information at your own risk.
