Page 1 of 2 12 LastLast
Results 1 to 15 of 20
    Jun 2016
    Budapest HUNGARY
    Default Yamaha Moric-2 keyprogramming with FTDI-TTL232 + PIC18F26K22
    All parts:
    Ftdi TTL232 adapter pins Txd Rxd GND Vcc
    Microchip 18F26K22 ( with program )
    10K resistor
    PC software
    Update info:
    run exe and unpack
    see pictures
    if you hardware build no problem i send license and 18f flash file (need write PIC18F2xK22)
    need original FT232Rx chip... A5.fixcode incorrect , FT232BL incorrect ! RQ RN RL if fixcode need swap
    i buyed USB cable TTL232 full 5V RQ version and good.
  2. The Following 16 Users Say Thank You to f2f2 For This Useful Post:
    alex_r_2001 (11th January, 2023), antwnhszr (11th January, 2023), Faraday (7th September, 2023), Ivan72petro (11th May, 2024), jenya (9th April, 2023), madaxe (11th May, 2023), MagicProg (9th April, 2023), megasosio (12th January, 2023), mexanico1971 (15th May, 2023), miroopel (14th January, 2023), nacar (25th July, 2023), Roxxas21 (7th January, 2025), sv2hqx (7th January, 2023), thaeerkh (20th February, 2025), vanos batam (25th February, 2025), winaiservice (11th January, 2023)
  3. #2
    Jun 2016
    Budapest HUNGARY
    Video
    Step 1. Software download:
    Software Download
  4. The Following 8 Users Say Thank You to f2f2 For This Useful Post:
    antwnhszr (11th January, 2023), Bllinda (14th January, 2023), jenya (9th April, 2023), MagicProg (9th April, 2023), mexanico1971 (15th May, 2023), nacar (25th July, 2023), Roxxas21 (26th July, 2023), winaiservice (11th January, 2023)
  5. #3
    Jun 2016
    Budapest HUNGARY
    Quote Originally Posted by f2f2 View Post
    Video
    Software Download
    Soft link Update
    Add manual synchron code to masterkey convert
    With license
    Kkl connect to pc
    But kline disconnect
    Run my soft
    Press Read ecu ( wait ECU max 10sec )
    And press "E" button
    In hex edit synchron code
    Press Enter and show ID4D page3
  6. #4
    Jun 2016
    Budapest HUNGARY
    Work Step1 and Step2
    In 1 hardware
    Synchron code reading from ECU with KKL-KLine
    Moric antenna write with more TTL cable
    1 pieces hardware
    Ftdi connect enabled:
    Red color TTL232 board
    Black color cable TTL232 5V
  7. The Following 4 Users Say Thank You to f2f2 For This Useful Post:
    alex_r_2001 (11th May, 2023), MagicProg (9th April, 2023), nacar (25th July, 2023), vanos batam (25th February, 2025)
  8. #5
    Jun 2016
    Budapest HUNGARY
  9. The Following 4 Users Say Thank You to f2f2 For This Useful Post:
    alex_r_2001 (11th May, 2023), MagicProg (9th April, 2023), rokibar (15th April, 2025), vanos batam (25th February, 2025)
  10. #6
    Aug 2016
    .Hex PIC18F2xK22 gracias
  11. #7
    May 2017
    algeria
    @F2F2 Its work only in xp ? i have win10 but i cant open the soft
  12. #8
    May 2017
    algeria
    and the pin out of ecu if you can
  13. #9
    Jan 2010
    EU
    Links dead?
  14. #10
    Jun 2016
    Budapest HUNGARY
    Quote Originally Posted by ollync View Post
    Links dead?
    Link dead ? Now link good
    http://f2f2.atw.hu/mesr.exe
    I check now win10 and works
    Defender set run exe
    Exe unpack
    Yamaha-moric folder need
  15. The Following User Says Thank You to f2f2 For This Useful Post:
  16. #11
    kiszka's Avatar
    Aug 2009
    Exe unpack
    the program does not work on win 7
    Reality of life :
    1:Never argue with an idiot, he will drag you down to his level and beat you with experience
    2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
    3:Jealousy is a sign of inferiority
    4:Everyone lies
    How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
    If you like to read garbage, don't slow down, just speed up
  17. #12
    Jun 2016
    Budapest HUNGARY
    Quote Originally Posted by kiszka View Post
    And you use only win7 ? no other ?
  18. #13
    kiszka's Avatar
    Aug 2009
    I don't think I'm the only one using it
    but maybe some library is missing that I don't have
    Reality of life :
    4:Everyone lies
  19. #14
    Jun 2016
    Budapest HUNGARY
    I now general old exe system from zip copy Yamaha-Moric folder and check with Win7
    The Moric write exe need communication PIC chip
    download zip
  20. The Following User Says Thank You to f2f2 For This Useful Post:
    kiszka (14th May, 2023)
  21. #15
    Jun 2016
    Budapest HUNGARY
    mesr.exe pack add old type win EXE create (Blue icon)
    Please try if Red icon new type exe problem
    If you build MORIC write hardware i send PIC18F... file
    find me in email
