Results 1 to 7 of 7
    Jun 2009
    Unhappy computer beeping
    Please I need help with my pc it starts up nicely when I am using it i will all of a sudden hear it beep like a timer than it restarts all by it self.
    I dont no if this is anything to do with the power supply watts the one i had before was 400w and the one i put now is 300 I think this could be the problem but still need help
    MAYFUSE
    Oct 2008
    how many beeps are you getting for a bit of help take a look here
    Computer Post / Beep codes
    Member moztas's Avatar
    It is probably a over heated microprossesor. PC shuts down itself if microprossesor temperature is so high. Check cooler fan of it. It could be a problem if cooler fan is not turning or very slow.
    Yeah sounds like overheating. Check if there is any dust on CPU cooler, clean everything. If this doesn't help, you'll have to remove the cooler, clean CPU and put new thermal paste.
    Before doing all this, i recommend to use some software (like EVEREST or similar) to watch the temperatures.
    Quote Originally Posted by orzo View Post
    Yes, it is good idea to check thermal paste because it gets dry because of overheating.
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Quote Originally Posted by mahf51 View Post
    MAYFUSE
    Download a monitor software for the motherboard. Another option could be a GFX/RAM issue, best getting make & model of motherboard and looking into it from there.
    If its overheating, get a can of air from a pc shop or asda, blow out all dust from heat sinks ect
    Meat-Head's Avatar
    Quote Originally Posted by cunny View Post
    More than one occasion i've come home with some pc from some where and it is black with thick manky dust, have just dunked them in the sink (seriously)
    squirted the board with UB40, dryed off with heater, used next day.
    At least 2 have done that to, but don't reccomended it, they were both free!
    removed psu and drives btw
