ok ive followed aftermaths instructions on how to do dbox and when connecting dbox to computer via null cable i get this below ,,, anybody help oot
Kernel command line: root=/dev/mtdblock2 rw console=ttyS0
Decrementer Frequency = 247500000/60
m8xx_wdt: active wdt found (SWTC: 0xFFFF, SWP: 0x1)
m8xx_wdt: keep-alive trigger installed (PITC: 0x2000)
Console: colour dummy device 80x25
Calibrating delay loop... 65.74 BogoMIPS
Memory: 30888k available (1052k kernel code, 368k data, 60k init, 0k highmem)
Dentry cache hash table entries: 4096 (order: 3, 32768 bytes)
Inode cache hash table entries: 2048 (order: 2, 16384 bytes)
Mount cache hash table entries: 512 (or
Buffer cache hash table entries: 1024 (order: 0, 4096 bytes)
Page-cache hash table entries: 8192 (order: 3, 32768 bytes)
POSIX conformance testing by UNIFIX
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
Starting kswapd
devfs: v1.12c (20020818) Richard Gooch (rgooch@atnf.csiro.au)
devfs: boot_options: 0x1
JFFS2 version 2.2. (C) 2001-2003 Red Hat, Inc.
i2c-core.o: i2c core module version 2.6.1 (20010830)
i2c-dev.o: i2c /dev entries driver module ve
CPM UART driver version 0.04
ttyS0 at 0x0280 is on SMC1 using BRGttyS1 at 0x0380 is on SMC2 using BRG2
pty: 256 Unix98 ptys configured
eth0: CPM ENET Version 0.2.dbox2 on SCC2, 00:50:9c:3d:a0:08
D-Box 2 flash driver (size->0x800000 mem->0x10000000)
CFI: Found no D-Box 2 flash memory device at location zero
D-Box 2 flash memory: Found 1 x16 devices at 0x0 in 16-bit mode
Intel/Sharp Extended Query Table at 0x0031
cfi_cmdset_0001: Erase suspend on write enabled
Using buffer write method
Creating 5 MTD partitions o
0x00000000-0x00020000 : "BR bootloader"
0x00020000-0x00040000 : "flfs (u-boot)"
0x00040000-0x00800000 : "root (jffs2)"
0x00020000-0x00800000 : "flash without bootloader"
0x00000000-0x00800000 : "complete flash"
Linux video capture interface: v1.00
mice: PS/2 mouse device common for all mice
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 2048 bind 4096)
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
cramfs: wrong magic
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000238: 0x1000 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000002a4: 0x0040 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000049c: 0x1000 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000538: 0x4000 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000630: 0x4000 in
stead
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000068c: 0x0040 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000007c0: 0x0001 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000009dc: 0x0001 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000a28: 0x0400 in
stead
Further such events for this erase block will not be printed
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020000: 0x4000 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020004: 0x0010 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0002000c: 0x0004 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020024: 0x0040 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0002002c: 0x0040 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0002004c: 0x0040 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020050: 0x4000 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020058: 0x4000 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020064: 0x0040 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0002008c: 0x0004 in
stead
VFS: Mounted root (jffs2 filesystem).
Mounted devfs on /dev
Freeing unused kernel memory: 60k init
Starting pid 11, console /dev/console: '/etc/init.d/rcS'ti-call b
Chip reports voltage low
Erase at 0x00000000 failed immediately: errno -5
Using /lib/modules/2.4.31-dbox2/misc/event.o
event: $Id: event.c,v 1.12 2003/09/30 05:45:38 obi Exp $
Using /lib/modules/2.4.31-dbox2/misc/tuxbox.o
Using /lib/modules/2.4.31-dbox2/misc/dvb-core.o
Chip reports voltage low on erase: status 0xa8
Erase at 0x00020000 failed immediately: errno -5
Using /lib/modules/2.4.31-dbox2/misc/dbox2_i2c.o
[i2c-8xx]: mpc 8xx i2c init
[i2c-8xx]: adapter: 0
Using /lib/modules/2.4.31-dbox2/misc/dbox2_fp.o
?debug: DDF: Calibrating delay loop... debug: DDF: 66.76 BogoMIPS
debug: LCD init error -1
debug: BMon V1.2 mID 03
debug: feID 00 enxID 03
debug: fpID 52 dsID 01-1d.a8.09.08.00.00-97
debug: HWrev 61 FPrev 0.23
debug: B/Ex/Fl(MB) 32/00/08
WATCHDOG reset enabled
dbox2:root> debug:
BOOTP/TFTP bootstrap loader (v0.3)
debug:
debug: Transmitting BOOTP request via broadcast
debug: Given up BOOTP/TFTP boot
boot net failed
Flash-FS bootstrap loader (v1.5)
Found Flash-FS superblock version 3.1
Found file /root/platform/sagem-dbox2/kernel/os in Flash-FS
debug: Got Block #0040
will verify ELF image, start= 0x800000, size= 152952
verify sig: 263
Branching to 0x40000
U-Boot 1.1.2 (TuxBox) (May 23 2004 - 21:44:01)
CPU: PPC823ZTnnB2 at 66 MHz: 2 kB I-Cache 1 kB D-Cache
Board: DBOX2, Sagem, BMon V1.2
Watchdog enabled
I2C: ready
DRAM: 32 MB
FLASH: 8 MB
Scanning JFFS2 FS: ....... done.
FB: ready
LCD: ready
In: serial
Out: serial
Err: serial
Net: SCC ETHERNET
Options:
1: Console on nul
2: Console on ttyS0
3: Console on framebuffer
Select option (1-3), other keys to stop autoboot: 0
Un-Protected 63 sectors
### FS (jffs2) loading 'vmlinuz' to 0x100000
### FS load complete: 619057 bytes loaded to 0x100000
## Booting image at 00100000 ...
Image Name: dbox2
Image Type: PowerPC Linux Kernel Image (gzip compressed)
Data Size: 618993 Bytes = 604.5 kB
Load Address: 00000000
Entry Point: 00000000
Verifying Check
Uncompressing Kernel Image ... OK
Linux version 2.4.31-dbox2 (sportster@bar-wsl01) (gcc version 3.3.5) #21 So Jun
19 18:44:54 CEST 2005
On node 0 totalpages: 8192
zone(0): 8192 pages.
zone(1): 0 pages.
zone(2): 0 pages.
Mount cache hash table entries: 512 (order: 0, 4096 bytes)
Initializing RT n
Starting kswapd
i2c-dev.o: i2c /dev entries driver module version 2.6.1 (20010830)
Creating 5 MTD partitions on "D-Box 2 flash memory":
cramfs: wrong magic
stead
stead
stead
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000668: 0x0004 in
stead
stead
stead
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000af8: 0x0400 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000ffc: 0x0400 in
stead
stead
stead
stead
Sel
steadtion
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000200c8: 0x4000 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000200dc: 0x0040 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000200f0: 0x0001 ininux Kernel Image (gzip compressed)
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000200f8: 0x1000 in
Entry Point
Mounted devfs on /devages.
zone(2): 0 pages.
Ke
Decrementer Freque
Console: colou
event: $Id: event.c,v 1.12 2003/09/30 05:45:38 obi Exp $librating delay loop... 65.74
Buffer cach
[i2c-8xx]: adapter: 01024 (order: 0, 4096
Linux NET4.0 for L
Based upon Swa
debug: feID 00 enxID 03ciety NET3.039
Initializing RT n
debug: Transmitting BOOTP request via broadcastle version 2.6.1 (20010830)
boot net failedion 2.6.1 (2001
ttyS0 at 0x02
debug: Got Block #0040 Unix98 ptys configure
will verify ELF image, start= 0x800000, size= 152952n 0.2.dbox2 on SCC2, 00:50:9c:3d:a0:08
verify sig: 263
Branching to 0x400002 flash driver (size
I2C: ready
I
DRAM: 32 MBtended Query
FLASH: 8 MB031
FB: readybled
LCD: ready
In: serial
Using buffer
Out: serial
Err: serialeating 5 MTD
Net: SCC ETHERNET 2 flash memory":
Options:
1: Console on null
0x000000
2: Console on ttyS0otloader"
3: Console on framebuffer0x00020000-0x00040000 : "fl
Select option (1-3), other keys to stop autoboot: 0x00040000-0x00800000 : "root (jffs2)"
.................................................. .............ootloader"
0x
Un-Protected 63 sectorsomplete flash"
Verifying Checksum ... OK0.
Uncompressing Kernel Image ... OKng magic
jffs2_sc
stead
19 18:44:54 CEST 2005lock(): Magic bitmask
On node 0 totalpages: 819202a4: 0x0040 in
zone(1): 0 pages.
stead
zone(2): 0 pages.
stead
jffs2_scan_era
Dentry cache hash table entries: 4096 (order: 3, 32768 bytes)0 in
Inode cache hash table entries: 2048 (order: 2, 16384 bytes)agic bitmask 0x1985 not found at 0x00000538: 0x4000 in
Further
Initializing RT netlink socketc bitmask 0x1985 not found at
Starting kswapd00 in
stead
devfs: boot_options: 0x1004: 0x0410 in
stead
jffs2_scan_
i2c-core.o: i2c core module version 2.6.1 (20010830)2000c: 0x0004 in
i2c-dev.o: i2c /dev entries driver module vestead
CFI: Found no D-Box 2 flash memory device at location zeroask 0x1985 not found at 0x0002002c: 0x0040 in
stead
cfi_cmdset_0001: Erase suspend on write enablederaseblock(): Magic bitmask 0x1985 not found at
Linux video capture interface: v1.000k init
mice: PS/2 mouse device common for all miceole: '/etc/init.d/rcS'ti-call b
Chip reports
IP Protocols: ICMP, UDP, TCP0xa8
IP: routing cache hash table of 512 buckets, 4Kbytesediately: errno -5
TCP: Hash tables configured (established 2048 bind 4096).o
event: $I
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000630: 0x4000 in0020000 failed immediately: errno -5
steadsing
[i2c-8xx]: adap
stead
stead6 Bog
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000af8: 0x0400 in init error -1
stead
deb
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00 dsID 01-1d.a8.09.08
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00002db0: 0x1000 int net failed
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00003748: 0x0400 inund file /root/platform/sagem-dbox2/kernel/os in Flash-FS
stead
stead2
stead2
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000201ec: 0x0040 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000201f4: 0x4000 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020218: 0x0400 in
stead
