Results 1 to 1 of 1
    Oct 2016
    UK
    Default help with 1.9tdi Caddy soi and duration
    I've fitted Pd150 (038 130 073 AL) injectors to my vw caddy but need help sorting the map as its obviously over fueling. I've been told I need to adjust the soi and duration? is that correct?
    I've attached my original file from my caddy and also the original file from the mk4 golf that I took the injectors from.
    Hope someone can help adjust the values in my original file or if someone has a file I could try as it is a common conversion?
    Tia
