Results 1 to 10 of 10
    AlimK's Avatar
    Nov 2018
    Sofia
    Default Problem with read EEPROM 93c46 Peugeot 406 IMMO
    Hello, I have a problem with reading of 93c46 (B58097) DIP 8 eeprom. I read with MCUmall GQ 4X but in .bin file (buffer) I show only F9 F9 (see picture below). I try to read another eeprom from another peugeot 406 same chip (B58097) and same reading.
    When I try to read NEW EEPROM 93c46, reading is FF FF (see picture)
    I am confused what a happend, have a problem with programmator and not correct reading, or EEPROM is faulty?
    Please help, thanks !
    Ninjor s's Avatar
    Aug 2020
    Bcm2
    Quote Originally Posted by AlimK View Post
    remove eeprom from board read with programmer and clean legs of chip.
    the lesser you use your brain,
    the louder you use your mouth.
    AlimK's Avatar
    Nov 2018
    Sofia
    I did it! I don't now why dump is with F9F9F9, maybe this is a problem? Programator GQ 4x is the problem or faulty EEPROM chip 93c46?
    Ninjor s's Avatar
    Aug 2020
    Bcm2
    try other programmer...............
    AlimK's Avatar
    Nov 2018
    Sofia
    I writed New eeprom 93c46 and read again, no problem writing is correct and after that reading is correct.
    So maybe the main issue is in eeprom's faulty/defected.
    Tomorrow I will try the solution and give you feedback.
    Oct 2011
    cameroon
    Or the first programmer is damaging eeprom content
    Dec 2009
    Does your programmer support 93S46 (93CS46) ? B58097 is 93S46 !
  8. The Following 2 Users Say Thank You to Zmann For This Useful Post:
    AlimK (4th February, 2023), fuzz1 (5th February, 2023)
  9. #8
    rafal's Avatar
    Jul 2010
    UK - PL
    Quote Originally Posted by Zmann View Post
    Does your programmer support 93(c)S46 ? B58097 is 93S46 !
    it is like users using only one programmer and playing with cars
  10. #9
    AlimK's Avatar
    Nov 2018
    Sofia
    Thank you! I try to read like as M93S46 and I read the correct dump. This is the file. So I will try to immo off, from my undesrtood just put "zeros" (00) in first 6 8bit possitions. I will try and give the solution.
    P.S: I tried with desolder EEPROM but not work!
    Original dump from EEPROM:
  11. #10
    Dec 2009
    (my reply to the PM) Checking the dump might not be that easy to find the corrupted byte(s). And also they are all too old. Your target was already Immo Off ? My all eep dumps are here, try them yourself, some is already off, for the rest you knew how simply to do it yourself too.
  12. The Following User Says Thank You to Zmann For This Useful Post:
    AlimK (5th February, 2023)
