Page 7 of 8 FirstFirst ... 2345678 LastLast
Results 91 to 105 of 116
  1. #91
    Aug 2020
    Quote Originally Posted by iflorea13 View Post
    @ crouchinggerbil
    No,because if serial test is fail,i,m afraid not to broke the tester.
    The software checks if the firmware is the same on the vci as it is in the software. Update the vci and you should be good
    HaynesPro 2025 online + AC/ Delphi 2022.02a available, message for where to get them!
  2. #92
    Apr 2025
    hi my system id is
    aUiYMdoAcs-hsTigE0V2cIqLdTX5D7Jfu1VCkfzWGQc
    many thanks
  3. #93
    Aug 2020
    Quote Originally Posted by Mikeywarduk View Post
    hi my system id is
    many thanks
    LQcaFAh2NxERNxscEVkME2IJJwsfYAZGNQc0JjoeC0U7CwMqMh hBKCYiGVohDkwDDjR8ZzoYLxE2JTBEM2waNzsDOG4iNiE3DjEy NW4JNywQOCsOOAZcHDAeKUc7CSk0ADRBGwhVMFsQCXIICh8HJD syLygECj8aM2waMwh3FWwRND0QCwQmEWAMFSAkYRICNgc3bjsf MUQ0BxhwBBhNCQ4xGQAiDkQ7EBwTCwgiMyABFxkyM2wVKAgoZh U6NSkyPRM6JHs1aigLFG4nBS0NBzMjNUIGMhcJAQsuGQpVESMh CX5SCWoDKwgzMycEMiMeM2waCQoNAW8lNTEpCjEXUHkmFW8JYC 9FACwKbT4wCAU3MgsCCRgEFjw9Mx0iDn0QEBEmKTozVF4/Mw4DM2wVagsAIxAVNzkXCy4ECHkODTQKFR0wAAEvDwwsMVkxJQ s0HBoAJQ8hCVoRJHEaDGsTGRFHNzoAGwoDM2wVbhV3YioQUDE3 OzE+NGMPDR8SOG5FNjwNKjsaKXY0NAsBBhkiKz5XLB4gUGZWC2 gLEQ5HJy8EMy8uM2VfYg==
  4. The Following User Says Thank You to crouchinggerbil For This Useful Post:
    iflorea13 (24th April, 2025)
  5. #94
    Mar 2023
    Default Is working.
    Quote Originally Posted by crouchinggerbil View Post
    Is working.
    When i tryed to test wasn't connected to the car.
    After connecting to OBD socket , testing was ok.
    Working fine.
    No software update needed.
    Many thanks.
  6. The Following User Says Thank You to iflorea13 For This Useful Post:
    crouchinggerbil (24th April, 2025)
  7. #95
    Apr 2025
    Hi, Kindly help with activation code. My activation id is:
    qo_cHDHRXcmwNrb_eZW33ZDiR9UgnuMZdZisN0YV8wM
  8. #96
    Aug 2020
    Quote Originally Posted by vmanyemu View Post
    LQcVJwouJxgXNgcyDVsMKHk6Ny0UODsNNVsWbA1EVmwGMQ8JMj REFiUIDlk5UUARPWl0KhIdWDg3byADM2waMgsTCRAWOQgcCzw6 D3kPLwALAGZAOywVFToiOU4AGGF3HjQEMDEyDVoVU3oKCBEXZw w8NBwxCRkaM2waJgASHmoQJD0hCz8iNVAkFQogOiszAAYdNwpE Vl0zMjJwBhoQOwggajgXGWIsDWofHToYNzIqFzs2M2waNgwTAQ sVUx8rOwUuKWM1FSgLKis4MAJcJTozKXIHGD0HHm4QFDkLFSAu NFgJOjULFRJFIyg/JSMyM2wVJQ0QGQcWNhMsPS4EN1EJGRARPRE6BDwNEDMwLUcpbz 0BBgouVzgtBSMhUwETOxE1Zj4hMwc/NF1AM2waEjooN20/UR8gDhMiGnk1GTQkOmY/MD8kbj8yKXY7Mm10MWwEGSZVGSYnU0QaBWoPPRIeNz8HNSNHM2 wVJxYDBREiUxhXOxMYCWAJK2wRYhUZADw/EjowD34wMzUqHjEcLTEga1ojJVwXEyB9KTsZVC0AGFguM2VfYg ==
    HERE you have everything you need to do it yourself.
  9. #97
    Apr 2025
    Hi, It says the activation code is invalid...
  10. #98
    Aug 2020
    Your code is correct for the ID you posted. Did you remove the spaces in the code? It the date on your pc todays date?
  11. #99
    Apr 2025
    thank you for the guide, the code worked after removing spaces..
  12. The Following User Says Thank You to vmanyemu For This Useful Post:
    crouchinggerbil (27th April, 2025)
  13. #100
    Apr 2025
    hi there!
    pls here its my id KXXpLOhQOUmhKVHb9bl8nV4LPKDDcJa0TPzI8WUKHPg
    when u can thxs u!
  14. #101
    Aug 2020
    Quote Originally Posted by Dexternillante View Post
    hi there!
    when u can thxs u!
    LQcaFxQQFTElOTEoO1gyUXokLy8fYAk8MgEJCQwfMVovNANzNh sYMDFUOys5JH4qPgwTAAUzWB48bj8yM2waEw8AajERNBsEPiw+ FmcJBRwgFR0HAC03MTswOQEzJTUMAQoiOw9WGS8nJVcbFCMcZw 1EJxk3CwpAM2waNhcTCWw5JwdXPQUuEGYPKyoRFRFFBAUjJggs OgYtCh8AAm05UTgwL1o6UwwaDmsXOBEhWD0rMRk6M2waHQgrER s6NwQXCActGlE1bjYgOBUEMD0zDThHNQcGCz43MjRFIggxNwQ7 Jg0yEiMhOj4aK10HNScyM2wabhQQJ286NwcRPCEuJn8bZgkXFR kHNCMBFzMjBAA2NR9zBTQuCTw2Zi8WGXoYDTcuKToiIz0HFzhA M2waBTh1HRUgNTpVCTw+LW0xLGofFx4GNj4dKTsjE3I7bBMPCR ouVz9XL1giUGZXDQEDCzoyBQM0JTMeM2waLjs/Cm4nU1oKDlsAJWI1K28kBmtHLAc3DjgYKUwubA8JCm4EJzkjOx 4nUlsVPTcXHTtEFSI2CllEM2VfYg==
  15. #102
    Mar 2025
    JD8mJDLkRisGCS-VYidMniMVzaeO82sPlWEViUWQpDA
    Please
  16. #103
    Aug 2020
    Quote Originally Posted by jjenterprise View Post
    Please
    LQcaJQp1KxIjJCEnCgM6OVEkNxIWOR03AAAJCjgaB00DbB91BA omMzkiNFwlNVAwCgwtFwozKx8/GBlHM2wabRQRFS4XCwgdC1oiC2YmEREWBTgMBCwvEjgsLUQvNA t0AmwcJwkJHlo5UH4uCDIpAAogKyMrFy9HM2waMAg8ahgiKS0u DC8xEVZSEQwXFDACNT8oKQtFCE03NGAUHQcEJwoJL1w4UUAJBm s1Gj08LycGCT8mM2waLAMDO2kmNyUzDhAAJlcJO2gnOBk9O1on FyYgCAc4GwMdMgkQUwg9HQYuGXonDDcDIA0eKyIEbj86M2waEB QAHTYmJCUoCAQ6VWZROzYJYS8mOzMJEDweIQUHCA8OHm8+KDgI NxsiDgELDWsLJz0aETMAClAmM2wVJT13amoRJj1WCj0cD2IlKw AhYBVCLi4Jbj8eC3gsbT0BMTQyMj4gFR8lCHokChwAKjoYJxoH Gg0aM2wVJQMQYgk5UwRXFFsYEWY1CSohYWY7O1sVFCVGVm0xNT UAADJFVyU9CSUWCXIJE2kpBDsZFSMyNQ0yM2VfYg==
  17. #104
    mohamad1401's Avatar
    Dec 2010
    DK
    HELLO
    PLEASE ACTIVATION THX
    tqowdMfiIba1GxlRQJkvW1GaU5LgwRvBtSpaW4N7Zhk
  18. #105
    Aug 2020
    Quote Originally Posted by mohamad1401 View Post
    HELLO
    LQcaKjgCPC0lORssBT8bG1YnEQomYgUtOwYjDQsyC0EvNAh0AW 86ETk9FhMWNGZQBR8pYTsfFV0BCT8aM2wVbzgQBWwmNC4XEgMc DVc3ESgnBDNFNCwKajAsLUcwCh8wGG4cCA4iKzw7NHohCwwxBD 4gOBkGbyM2M2wVJhcTPw8tDB9XDD5FNGYOPG0IORUfNT4Vbjgg MX8sBwwyBQwALQ8yMyUjN2YgBREDAj4YNx0xGAUOM2wVLQMREi YWJh8mPhMuElAOESMQODMdNiwGazs8LVUzNAsDAW0EMiYgbxMi UlgbEA0pPAozWBwzGycOM2waCQgpPykiUAxXDS8YUWAIFRUgFi dCAFk3PgtEUkwAJTEQCQsYKjhWDVw5JABTPREtJQ0gJwUzCBky M2waDw90AQolDzoSESxBMGYPJxYWBAoDMD4RKAsOB3Y7MRwzAm wiKiUPET85UGI2PWl0ZhIsN1kxGFgCM2waFgB2NyUXUAMQPhM2 G2EJLG0WGxE9OywoKCQsNVgAby0dMm0+Mj0OZhoiN24sPBwDIT 48BRoyCBk+M2VfYg==
  19. The Following 2 Users Say Thank You to crouchinggerbil For This Useful Post:
    mohamad1401 (7th May, 2025)
