    Newmotors's Avatar
    May 2019
    brazil
    Default Problem Map Audi A1
    hey guys, i need some strength with an audi a1 med17.5.5
    I made a Stg2 map, redid it about 3 times and I have the same problem, when I drive with the car only on restarts it cuts the boost from 222 to 120 and it gives me the fault P0097
    original NO PROBLEMS no cuts and no flaws. I don't know where I could be going wrong because I've done it 3 times
    Part Number: 03C906016AD
    SW Version: 8930
    Hardware: 1.4l R4/4V TS CAXA
    Serial number:
    ASAM: EV_ECM14TFS01103C906016AD
    Coding: 00250012000400000000
    CVN: 7A6E699F
    Reprog count: 6
    ECU: MED17.5.5
    Completed
    I WILL ATTACH THE MAP AND THE LOG
    Thanks !!!
    Feb 2013
    Post the original file too.....is it dsg or manual gearbox?
    Newmotors's Avatar
    May 2019
    brazil
    Dsg7 Friend ..... Ori file
    Newmotors's Avatar
    May 2019
    brazil
    does anyone have a full data for this ECU?
    Newmotors's Avatar
    May 2019
    brazil
    Has anyone ever gone through this?
    Newmotors's Avatar
    May 2019
    brazil
    Can anyone provide me with damOS for this ecu?????
