Results 1 to 15 of 6019
Hybrid View
    Oct 2024
    potrebujem pomoc. HkFdFaFtOOVSUWH5EoyJUzg2AgxSsvRIP3Cxpbmwb2w dakujem
    Oct 2020
    Quote Originally Posted by SStano01 View Post
    LQcaJzopGWkuJw8fCS0mL2AlJ28kBA1HLVoNESJFLUU2Ggt1MW 8uDDgLCloWJFhQDDcTYj0wMworMQ0yM2wVbQwAGQ0iDB88CD8i U21SMysTOC8bOAZUEQ1EWlkACxN0AjUQMwhWMB8VJFAIOzU1Cg YgMzMBbR1HM2waBzh3GRsWNxsRCiE6AmdQCTgfYDs+BAU0KQwd F3EHFxsLCW8QNToPDQQXJnoVBiAxFRIyLF4ACCcaM2waLDh0Nw w4Ui0iDjw6LG0MLyEKGw4MA1sdLiYhMkw2CRcSAjIMKQgJBhEi CV9TPR0fFQ4aEQoEMjsuM2waBxYQBSY6UyE3BlkcLFAYFTYQOR k9NyhcNwwhNgYsGBBwATUiUQpVFhElU1w0CmoHPwkjNyk2CAE2 M2wabhQQZyclCh8sPAIuDWc1ZisTFm5AMjM/NjojLUMxCQB2NwsYAAg9GR0uK1gMDDJwEBEzGQM8Cy8eM2waGg MQYiwtNFohEgQuE1cPEmgfBxYGAD4zEggYIk0sGz0fMgc9UQ4y MxAVDmZSCzMPYhRGUF8rGRkaM2VfYg==
    Oct 2024
    Dakujem ale nefunguje ten ID kod
    Top Poster Golf4's Avatar
    Apr 2023
    Bremen
    LQcaJjsrMCY5NCU/BS0mKVE1GTMXOGpFO1kzLwgYE0I4MjE1CQkXFwkPHTkQCVwxPB EHHhEfUDEHMlwOM2waCAMDFSwQJBsNOi4AUWEIMx8SFi8DBC0B bjs8EwE3FxMpCgk5Uwoibi0mO3IgOzQQYwYjCQIrbjMuM2waCg MSFQYmJykrET8yNGA3OzERFmYgAgARJwgYJQUAJTUVHBkuVyYw ERslUFgqBWkxBBEiK18qGyhAM2waKToDMG45Nh9WBgAAClcPMy AfFRkALD0oLQoZBAE0Gz0pMm0EUiQjHSoXJlwJCWgpGDsaJzE/bgpEM2waLDsDESc4UgMPPAUYJ2M3Zg4UKTchL1kvJQtGCEI7bj 0MHQgEGyUwKwgtUw0TDTUtGBIyKwYACSc+M2waDwsNPCc7JiEg EQQmCW00FSgWYC86MFg/CSQgOWEGbykdNwg6ND4OL106Dg0OBTcqKjwYIx4rCys+M2waDg g/BRY7JD0RPC4XVmI2CRMQYi8hOAYwbgwxD1svGGAVBQguKTE9DR 87O1APEhETBQ0jKzkENh0CM2VfYg==
    Don't forget to press the thank you button here
  5. The Following 2 Users Say Thank You to Golf4 For This Useful Post:
    LeMatt (17th May, 2025), SStano01 (16th May, 2025)
  6. #5
    Oct 2024
    dakujem ale nefunguje ani tento
  7. #6
    Oct 2024
    potrebujem pomoc s ID kodom HkFdFaFtOOVSUWH5EoyJUzg2AgxSsvRIP3Cxpbmwb2w dakujem
  8. #7
    Aug 2020
    LQcVbQwAGQ0iDB88CD8iU21SMysTOC8bOAZUEQ1EWlkACxN0Aj UQMwhWMB8VJFAIOzU1CgYgMzMBbR1HM2waBzh3GRsWNxsRCiE6 AmdQCTgfYDs+BAU0KQwdF3EHFxsLCW8QNToPDQQXJnoVBiAxFR IyLF4ACCcaM2waLDh0Nww4Ui0iDjw6LG0MLyEKGw4MA1sdLiYh Mkw2CRcSAjIMKQgJBhEiCV9TPR0fFQ4aEQoEMjsuM2waBxYQBS Y6UyE3BlkcLFAYFTYQORk9NyhcNwwhNgYsGBBwATUiUQpVFhEl U1w0CmoHPwkjNyk2CAE2M2wabhQQZyclCh8sPAIuDWc1ZisTFm 5AMjM/NjojLUMxCQB2NwsYAAg9GR0uK1gMDDJwEBEzGQM8Cy8eM2waGg MQYiwtNFohEgQuE1cPEmgfBxYGAD4zEggYIk0sGz0fMgc9UQ4y MxAVDmZSCzMPYhRGUF8rGRkaM2waBgMrBRMuCgMVCSE6IVYkOx 8nFQkfAj8/LT0sMVsvNQMdAAscNjIOagUWNGY1Eh51IREeCVs8JTgDM2VfYg ==
    HERE you have everything you need to do it yourself.
    HaynesPro 2025 online + AC/ Delphi 2022.02a available, message for where to get them!
  9. #8
    May 2025
    Please help with: 1dWZ0_PQd0Sq_LVEOcZlumIhBbYNkzapZqoibF4ksVM
  10. #9
    May 2025
    slovakia
    hello friends
    what is the difference in installing software for type 1 firmware 1622
    and type 2 firm....3201
    I first try type 1
    my activation ID: 37ATJVwgo1iu-whcmoiaoBhZgYtey6xOi6Hb3QoydtU
  11. #10
    Aug 2020
    Quote Originally Posted by gladio View Post
    hello friends
    I first try type 1
    Type 1 is for double pcb vci and it only works up to 2017 and then you have problems with newer vehicles.
    Type 2 is for the newer single pcb version and it is good for all if it is a good quality one.
    You physically need to open your vci to see what you have inside, 1 or 2 pcb.
    LQcaNBV1OwgtOQcxCD0iUFEPCiMkPg05NQU/NSQwMW42GzJ2HBcyVTkLBSU6JW4QCx4DZwpEK1kECz9HM2waLA p0BRQiDD5QBgMuCWA1K20mPy88MllUFA0yIVwpbwMJMBcYJwlV Zj4iUVgRPjUuYQ08EQcxMg0iM2waGw8SPwUgNiUTCQMXUW4YEQ MfOREGMiwvbT0ZWgUGbxw3Hm8iMQgxFVkuU2JUOjQ1Jz4xKFoH CicGM2waCwwuYjEXJjEVCAcTV25TNCEKBDM+LC0zHQ0yIQUwND UwCTIcDw8JETwRNg0vCTIfJwpGGSA0bCsiM2waawwTHR0hNj0i BT0yJm1RGQoIPgUVNwcVFz8iB0UDCTUpAm9NKD0jL1glDVguO2 kfHA0xGVsBNQJEM2waMDwuFRY/UilTEVlMEWcYBQMmGwlGMlgNDQshF34AChwzGG4XVCYyMzggJn pSBjILAwwzVAU8bgIDM2wVbj0NGS4tUV4TPiw+MVU3LykWFw1C N1kNETNGC2w7CRcVMQkcJgoJOwIgUXoYCyMDPQUeI14zMlwyM2 VfYg==
  12. The Following User Says Thank You to crouchinggerbil For This Useful Post:
    gladio (17th May, 2025)
  13. #11
    Aug 2020
    Quote Originally Posted by bsp89 View Post
    LQcaFD0BHW8XClJRDVsuKlYbZm0fBhkNLi4jLjNFD0EACmAXH2 0tUCUgbloWDXYhBR4mZj0xER0yGSdHM2wVbzt0IzIgNF40E1gl FWA6Gi4WCxVCNQArNTMeMVg4MRg/HjU1VTIJBQQjJlgzEh4hGDohOxwGbDM6M2waFRJ1Kz4nNi08Oz 4QIVZTHWohPhoNMFsJNgoZC180MRQ8CQoDVT0PNFwnJ35WCg8t AREZOx4BbiRAM2waEww/OwkQND09DQU5FWM6Fi4UBAkGNFojDiQzMQQ7MSkLGG0ALTkyMB AhUFsbDQ0tGxAjVCkGbVgeM2waJRR2GW0/UT03DlsyM2E3CRccYWdBNy5dJzosJV4GbykuCjIADAgyZ1wjO2 4OOxwPZg0sLx4HGBFHM2waFBQpFRIWJgBQE1oiVWMIDQMkBx5G NFkdJz9EWkU4bzJxBhouUj8ibjo6CGYlBjIcKzwODR0oCg0yM2 wVbDgTFmonUANQEj4+OWMOOGgmYgkdNFk3GjNFEwI0FzE3ARsi MT8fOwUWCkAPPjUhIT0hES0HbCQDM2VfYg==
  14. #12
    Oct 2024
    dakujem ale nechce mi to fungovat
  15. #13
    Aug 2020
    LQcaGgMQYiwtNFohEgQuE1cPEmgfBxYGAD4zEggYIk0sGz0fMg c9UQ4yMxAVDmZSCzMPYhRGUF8rGRkaM2waBgMrBRMuCgMVCSE6 IVYkOx8nFQkfAj8/LT0sMVsvNQMdAAscNjIOagUWNGY1Eh51IREeCVs8JTgDM2waGj wuKy4iNiUtCgQQN3snKxcQOR0iBDxQbiRHMUIGMTJwGG86Uwkw LystO1w3Og8DYApHDhw2bQ06M2waDTh3OG8hNg8/EDEhUmA3ERsLFgUMNi8nLQgxF2AsGT0LCQkELj5UMxkVJ3oYC2 oPGjsxFSMHMQ0OM2waEgASBSgVJT0yECEyNHoOHRohCw0iMjMO bDNFIUEGGg91BwobVTExGTk6J2VWDjQ1ITwhKBEGbDsuM2wabA gdAQ05NB8/OwJFOVYbKzAIBCcaBTxcFjpGC104FykvMjQiKTIOGTAnUnYsDR 4uIREaJykoNSM2M2waFTsQAmoWGykPBTxBV1EJZi0UOCsCAwZR ajgOKk4HMQMcMDEyNAgxCl0tDg0SBQEpOxE3FQowGlgOM2VfYg ==
    Your code was generated 5 days ago. Code only works on the day it was generated
