Results 1 to 12 of 12
    Nov 2009
    Prijepolje-Serbia
    Default Need info on decoding VW Radio Navigation...
    I have only sticker picture:
    Made by Blaupunkt
    7 612 002 042
    BNO 881
    Radio Navigation
    1K0 035 191 C
    VWZ1Z2...
    Anybofy have info where is code?
    FIS or SPI eeprom?
    Known code dump?
    Regards
    Mikeli
    Jan 2010
    DUPNICA BULGARIA
    Code is in the FIS.If you have tda 7432, pin 19 is SDA, pin 18 is SCL.
    Nov 2009
    Prijepolje-Serbia
    Quote Originally Posted by ilian_cho View Post
    Thanks,
    I'll try today...
    Standard situation, code is in
    2.4 and 6 row?
    Rgegards
    Mikeli
    Nov 2009
    Prijepolje-Serbia
    No FIS inside...
    Only ST 95320...Here is the dump...
    Somebody already tried to decode it, so I'm not sure dump is correct...
    Mikeli
    alexics's Avatar
    Jan 2010
    Kidderminster
    Quote Originally Posted by mikeli View Post
    No FIS inside...
    Mikeli
    Where is the dump??
    Nov 2009
    Prijepolje-Serbia
    Sorry,
    here is dump...
    Mikeli
    Quote Originally Posted by alexics View Post
    Where is the dump??
    alexics's Avatar
    Jan 2010
    Kidderminster
    Sorry,
    here is dump...
    Mikeli
    The code for the radio is here in your dump.
    0C20: 00 00 00 00 00 00 00 00 00 20 01 00 34 32 00 00
    0C30: 38 36 00 00 3B 39 00 00 3D 3B 00 00 3F 3D 00 00
    0C40: 41 3F 00 00 43 41 00 00 45 43 00 00 47 45 00 00
    0C50: FF fF 00 00 00 01 01 00 12 34 00 00 00 00 00 00
    The sequence 12 34 is often used in a Blaupunkt code area. You could try the obvious code of 4286 or 8642. Let me know if this works.
    siti's Avatar
    Sep 2009
    RO-ALBA
    MAN,code in fis & 0000-1999
  9. The Following 2 Users Say Thank You to siti For This Useful Post:
    kappa1 (27th October, 2014), kodey (13th February, 2019)
  10. #9
    alexics's Avatar
    Jan 2010
    Kidderminster
    Quote Originally Posted by siti View Post
    Didn't he say he couldn't find the fis? So where is the code?
  11. #10
    einet's Avatar
    Dec 2009
    Post serial complete.
    einet
  12. #11
    Nov 2009
    Prijepolje-Serbia
    Quote Originally Posted by einet View Post
    einet
    I'm not sure it's original dump... Someone before me tried to decode it.
    I'll call customer later and get serial...
    Regards
    Mikeli
  13. #12
    DK Veteran ACDC's Avatar
    Feb 2011
    I'm just curious. How did you calculate 4286 and 8642? If I convert 1234 into decimal I get a different number...
