Results 1 to 7 of 7
    rj22's Avatar
    Default BMW E46 eeprom error EDC15M
    Hello
    who will help to fix eeprom, I have an eeprom error non -stop
    Thank you
    rj22's Avatar
    Possible IMMO OFF or VIRGIN, or translate ISN into efficient eeprom ?
    Nov 2016
    What ecu nr?
    If I helped you, click on reputation and thanks.
    If you don't thank for help and give a reputation, you won't get help from me again.
    You use my help at your own risk.
    rj22's Avatar
    Nov 2016
    You can try to do immo off, but you will probably have to read also 2x eeprom 27c1001, you can also make a file 24c04 under synchro with inpa, or move isn to a new ecu, or buy an ews emulator and it should also fire.
    rj22's Avatar
    I also read Flash Galletto
    Nov 2016
    Isn in your file eeprom 6D FF
