Results 1 to 4 of 4
    Jul 2016
    Default Ford Explorer 2021 active alarme by pass to program key
    Hello pls iany help to by pass active alarm in ford explorer 2021 i try the way to wait 13 minutes til the horn will bip but no success any other way to obtain security access ?
    Jul 2016
    hello any help pls ??
    Sep 2021
    NA
    Close all open doors/hood (just the latch with a screwdriver to trick it to think it is locked) and do not get into the car or make noises to not to disturb the ultrasonic sensors and let it sit for 15 minutes (ignition on if it is a flip key), you will hear double-honk when it is off and you will have 30 seconds to program.
    The only other way I know is using FDRS. You will need a single VIN license (and be eligible to obtain it).
    To help you more, share what tool are you trying to use.
    Jul 2018
    I can try to help with this car remotely.
    Ford / Linkoln / Mazda PATS remote module and keys programming service
    VAG MIB1 MIB2 headunit programming, coding, maps update, language conversion
    GM remote module and keys programming service
    BMW module programming, coding, maps update, language conversion
