all 3 wires are connected to ECU
Three wires? This seems to have only two.
Here is picture of the component that was changed
https://www.motor-doctor.co.uk/produ...sure-converter
yes exactly, 2,0tdci is produced from 2006 so for exact question is exact reply ;-)
there are 3 wires for vgt position sensor - located on vacuum bank on turbocharger......
Let's try again. The car is made 2011. I attached the picture of the component which has only two wires in connector.
"Turbo Pressure Solenoid Valve,turbocharger Boost Valve 9652570180"
engine code or kW?
2.0L Duratorq-TDCi-DW AZWA
2.0L Duratorq-TDCi-DW QXWA
2.0L Duratorq-TDCi-DW TXWA
2.0L Duratorq-TDCi-DW TYWA
2.0L Duratorq-TDCi-DW UFWA
2.0L Duratorq-TDCi-DW UKWA
fuse 12 is common for egr and vgt.....second wire goes direct to ecu....
According to google error code P0045 is about "Boost control solenoid"-circuit. Is that same as "Turbocharger Variable Vane Actuator" in diagram?
Did you check vacuum circuit, some time if there is a damaged actuator or vacuum leak ,come code P0045.
