Results 1 to 15 of 24
    Apr 2017
    England
    Default Skoda Fabia 1.9SDI EDC15VM Problem After Tuning
    Skoda Fabia 1.9tdi vp pump 65hp _engine electronics edc15VM
    I have a problem after writing the file,it doesn't matter if I did a remap, egr or dtc or just change a number in some card, the car starts turning on and off, as if for an immobilizer. It doesn't matter what the file, galleto, kess, mpps, v18, v21 will be written with , in 16, or what will the check sum be calculated with, the problem is the same, has anyone encountered this problem by chance???
    Press thanks + reputation
    Apr 2017
    England
    Man, do you think that if there is a problem 109 I will write here ................A little more seriously, I wrote that the car only has a problem with a MODIFIED file
    Nov 2016
    Maybe you can move the wrong maps if the original is ok?
    If I helped you, click on reputation and thanks.
    If you don't thank for help and give a reputation, you won't get help from me again.
    You use my help at your own risk.
    Apr 2017
    England
    No matter what is touched on the original, the car won't start, not even one percent driver swish or torque or smoke it doesn't matter what it is.Тhe car starts to turn on and off...
    Dec 2018
    Hi, what did you read first? What device. Did you upload the first changed file? Or another tool? You can try to find another ori file and do a recovery with kess and then see if car start
    Nov 2016
    Write what you need in this file, we will try to do it, upload and see.
    Apr 2017
    England
    I tried everything I could think of...including what you say, I have all kinds of devices from Chinese kess, mpps, galetto, to autotuner
    May 2017
    Wrong chks
    Luigi84's Avatar
    Dec 2022
    Italy
    Default Skoda Fabia 1.9SDI test
    Skoda Fabia 1.9SDI test checksum
    WALES
    Quote Originally Posted by Luigi84 View Post
    File in post#1 is Original, checksums are original to car
    wbr
    WALES
    Quote Originally Posted by tdicustoms View Post
    Post your modified file and we can fix the Checksums for you... problem solved...
    wbr
  12. The Following 2 Users Say Thank You to shooting For This Useful Post:
    076458C (5th March, 2023)
  13. #12
    Apr 2017
    England
    I tried manual,swiftec,VagedSuite,Ultimo...Same think
  14. #13
    AVDigitale's Avatar
    Apr 2017
    Best Place in the World!
    something is from the tuned file wrong touched ,not possible not to start with chks ok ,but you maybe maded checksum with other tool then and kess make too and car no start
    post ori and you tuned files to see what is wrong
    Proffesional ECU & TCU Tuning
    Petrol and Diesel Engines
    File Service
  15. #14
    Apr 2017
    England
    Colleague, my respects, but you obviously don't read what was written above. I repeat, whatever is touched in the vtv file, even if the gas pedal or torque is touched with one unit, the problem is still the same...
  16. #15
    Jan 2013
    POLAND
    Please extract the ecu to the table and open it. I had it in the Vw LT EDC15, there was a stand mounted in the ECU and it ~~~~ed up the job. It is possible to read and write after OBD, but it does not enter the entire file. Regards
