Results 1 to 5 of 5
Hybrid View
    Mar 2021
    Default Mercedes Edc15c6
    Hello guys my friend have problem with Mercedes sprinter his ECU got burned down totally so it has CR2.35 Edc15c6 and we bought new ecu it's Edc15c6 CR2.11 if i'm not wrong now when we plug it we get Safe Error on dash because of immo now i swapped eeprom 5P08c3 and now we don't get error on dash everythings okay but car wont crank and even if we try directly to power it up it's just cranking but not starting, now i can't swap Maps inside ecus because ECU is totally burned down so does anyone has original map for this ECU
    A 000 153 42 79
    FD 01M05
    HW 14.00
    SW 09.01
    001 ED6040 CR2.35 2.2L MQ3+MS3
    0 281 010 826
    31.05.01 28RTF000
    18531 7450 0149
    or does anyone know solution for cranking and starting this Engine
    Dec 2018
    Hi. As it burned the old ecu, it could damage the eeprom. I propose ori eeprom from the new ecu to make virgin and see if the car start. The Sprinter was famous for losing the synchronization of the ecu immo box. You can desolder and transfer the 29f800 flash or read it on the table with a programmer. Best regards
    Mexaniks's Avatar
    Mar 2013
    UA ODESSA
    The problem is not with the map. He must start. The ECU died from a short circuit. There is a problem in the wiring of the car 100%
    The problem is not with the cards. He must start. The ECU died from a short circuit. There is a problem in the wiring of the car 100%
    Mar 2021
    The car mechanic said the short got when 2 cables on ECU pinout touched together and then it burned down
    Mar 2021
    Hey guys, i managed to read map from old ECU and i writed it to new one but still no cranking on key and we tested out with multimater when we turn the key for starting it gives signal but it just don't want to crank, we don't know what to do anymore, about eprom i think it's okay because there is no SAFE ERROR on board on cluster when i swapped eeproms. Is there possibility to virgin it? Do you think if eeprom is problem that car wont crank at all? Thank you guys for helping me
