Results 1 to 10 of 10
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Default Opel corsa E 2017 1.3 TCM problem
    I have an opel corsa E 2017 1.3lt with marelli tcm auto gearbox, in box there is engage gearspeed but in dush I hame N and car starts....(after few secs turn off because off the gear in gearbox)
    No dtcs in engine and in tcm ecus....
    Do you know anything about that?
    Dec 2018
    Hi. See the gear position in the parameters. Sometimes the dash shows N and there is one gear left in the gearbox parameters. And it doesn't show an error. Also check physically if you have N if the car is going to push forward or backward. If so, you can try a short starter or car start.
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    In live data, I see no gear engage in gearbox, the ecu doesn't see any gear engage, is there any sensor that shows which gear is in the box?
    Nov 2017
    Dobruja
    Can you make gearbox addaptation with any tool? Does it have any clutch disk changed recently? Or gearbox transmission oil leak? Can be some wearing on clutch disk and it needs to readdapt the gearbox, in order to change gears ok. Yes, the gb has a sensor to detect gear shifter and show in dash the actual gear.
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    I use gds and launch(dz) have the same adaption option....
    Nothing change..... I make depression, new disk installation and calibration still the same.....
    I see in live data oil pressure 49 psi? Is that normal?
    I try with launch to make gear engage - change, I can hear the motor moving, but can't get any gear.... ecu still see N....
    Nov 2017
    Dobruja
    I don't know the normal fluid pressure. Did you do addaptation, put in P and take off the battery? And after repowering it, to see if dash can show P? Check the GB ecu plugs, clean and reconnect them and see what happends...
    If you have access, take off the gb ecu and take a look inside
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    It can't put any gear......
    Is in N position, when I press selector, it try to put a gear but it can't...
    Maybe hydraulic valve problem???
    In diagnosis I see tcm T57..... Owner looking for other one.....
    Is this ecu closable? Io terminal can read it?
    Nov 2017
    Dobruja
    OPEL/GM TCM ACTIVATION modules list and functions
    TCM 6T30,6T35,6T40,6T45,6T50 FULL AM29BDD160GB FLASH R/W. CAN (OBD).
    TCM 6T70,6T75,6T80,6L45,6L50,6L80,6L90 FULL M58BW016DB FLASH R/W. CAN (OBD).
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by volodin69 View Post
    Yes.... I know what io terminal can read but I can't find any info what mcu this tcm have.....
    Tcm T57. Marelli
    55492258
    55486247
    Nov 2017
    Dobruja
    That is why i've told you to open the tcm ecu
