Hi....can anyone calculate longcode for polo 6r 2010 with Bosch 8.2. it doesn't have Tpms, hhc or xds. It doesn't have esp as no button inside to turn off. I have attached the build sheet with vin. Thanks.
Tools owned..... Kess3 Master, Bitbox, TGFlash, VVDI2 Full, VVDI Prog, VVDI MB Tool, VVDI Mini Tool, VVDI Key Tool Max Pro, VCX series for BMW Ford Mazda Jaguar Land rover VAG Toyota Volvo GM, PCM Flash + Scanmatik2, Lonsdor K518ise, Magic tank and every other piece of Chinese crap out there.
i need ref ecu abs for calculate
Think Thx an rep buttons !!!
darrenhyland (6th March, 2023)
Will this do?
Any help here guys? I'm onsite and trying to get to the next victim/customer.
try.....................
510224C2006F00B98A2924E600D800400000
or
210224C2006F00B9842924E600D800400000
or
110224DB006F00B9882924E600D800400000
or
Sorry mate........ neither work. Error 22 coding rejected.
sorry for you !!!
You did not provide information of the ABS system that is installed.... how do you expect someone to provide coding for it? Even by VIN, if people have access to certain systems it does not reveal the software that is on the system. If you are still in struggle ping me up. I will fix that.
EDIT: and never ever ever ever never ever use codings from people going "try this, try that, try this one",... this is a safety system and the parameters in coding affect how it works! There is only one coding that matches the vehicles parameters so don't try and take the one that is accepted. For people's sake that are driving with that car.
EDIT2: I saw posting a picture with the ABS system in it. Easiest of all, no parameters in it. Anyways. Just post a full scan rather than taking pictures of your screen showing the software that is capable of taking a full scan. My gosh.
EDIT3: what I mean is, get in touch and you can have your coding in case you still need it.
darrenhyland (14th March, 2023)
