is your problem solved yeT?
i think you must get the same cluster as original
ParamoTronic (5th March, 2020)
hi i have an audi a6 2000yr 2.5d autotransmision.
The original cluster is damaged and i replace with another one with same specification but i neet to program on car.
Cluster is Magneti Marelli with motorola mcu.
can someone halp me to find pin car from dump?
and another quiestion ...what pin i need to program new cluster?i ask this becouse the donor cluster is from another car is not new an have stored a pin from donor car.
I attached both dump from original cluster and donor cluster.
PS i can't disasemble cluster becouse is in waranty ,have a seal on it.
Dump was readed with vag tacho 3.01
Hello.
Read by normal reader and send again your dump please!
and we will try help for you.
Hy i need car pin for program new cluster
attached is dump from 24c04 ecu bosch
reference data:
4B1907401A
0281010095
is an audi a6 2.5 d automatic gearbox from 2000
edit:and if is posibble an immo off
65535 is maximum number that can be introduced.i try and dosen't work
there is no login stored in your ecu as it is immo2.
login stored only in dashboard.
