    Feb 2022
    Default Jaguar XF question
    Hi guys i have corrected the Miles on a 2014 Jaguar XF Via OBD with the tool SMOK
    after the mileage was corrected the software stated that if the dash is in a ( black state ) then either pull the dashboard fuse or disconnect the battery,
    I disconnected the battery and then reconnected it and everything came back on and the miles where displayed correctly, But i now seem to have a problem with the central locking which was not there before ?
    when i press the key to lock the car only my boot and fuel cap lock ? all other 4 doors do not lock and the car makes a double beep noise which is a indication that there is something wrong with the central locking.
    I have read on the forums that if you disconnect a battery from a jaguar that it can cause this problem and that you need to then use diagnostic equipment to tell the car that it has had a new battery or that the battery has been changed.
    My question is has anyone come across this before ?
    is there any truth in this ?
    and is there a fix for this please ? any help would be mostly appreciated as always thanks
    rafal's Avatar
    UK - PL
  3. The Following User Says Thank You to rafal For This Useful Post:
    Dashmaster (9th March, 2023)
    Feb 2022
    Thank for the reply i have had a read through all that topic and it is very helpful, but i don't seem to have the problems of the car not recognising the key or the car not starting, so not sure if it is a corrupted bcm ?
    My car has all working aspects but only central locking issue iv given you thanks in your post for the help anyway
    Sep 2014
    UK
    you'll need SDD and run immobilisation
    Feb 2022
    Quote Originally Posted by jacek77 View Post
    yes i have seen that people are talking about SDD and immobilisation, any idea if Launch X431 or Autel IM 908 would be able to do this function as i can get access to these tools tomorrow ?
    Dec 2020
    infuture dont disconnect the battery , pull the fuse in the boot , I read the link above before I did my first one as your issue is a common one , not to helpful I know but...
