Page 11 of 12 FirstFirst ... 6789101112 LastLast
Results 151 to 165 of 180
  1. #151
    kire106ka's Avatar
    Aug 2012
    MACEDONIA
    The rule is if immo light no flashing immo off just cut wire 35 before plug ecu to car
    Repeat procedure onse more to be sure no harm to ecu.
    IF YOU THINK IT'S EXPENCIVE TO HIRE A PROFESSIONAL,WAIT UNTIL YOU HIRE AN AMATEUR
  2. #152
    Dec 2011
    Quote Originally Posted by wizz2c View Post
    try this method first very easy ,post results please
    Hi guys,
    Working 1st easy solition for me ECU lamp stay on
    But i've tried 20 times these procedure, last 5 times with sliding tweezer. Tomorrow i will test on the car and reply the result.
    Thanks a lot,
  3. #153
    Member OalikO's Avatar
    Aug 2013
    Moscow
  4. #154
    does this work on 2000 year clio 1.2 8v?
  5. #155
    Feb 2011
    Almeria, Spain
    hello
    thanks by information
    but i undersant "you have 9 pins either side,so 9 on A and 9 on B, short 1A with 1B then 2A with 2B all the way till 9A and 9B.holding each for at least 2 secs, engine mngt light should go out,car will then start."
    please explain
  6. #156
    Feb 2011
    Almeria, Spain
    cut immo wire to stop immo causing immo off status in ecu usually pin 37, ign on follow procedure in txt file.
    hope this helps
    hello
    i can explain the method of the pin ? It is about flash o eeprom?
  7. #157
    Feb 2011
    Almeria, Spain
    Quote Originally Posted by ninja123 View Post
    hi guys, had a 1999 megane scenic 1.6 8 valve with immob light flashing, transponder in key, both keys not working.
    After i eventually removed the rubber floor mat from the chip, i wired up on bench and I shorted pins 1-9, had to do it 7 times before my light stayed on.
    Cut pin 37, fitted ECU to car and worked first time!!
    Thanks to all who have contributed to this thread, once again, great work guys!!
    regards, the ninja
    hello
    i have some ecu and car
    Can you explain the process to short pin?
  8. #158
    panos_k's Avatar
    GR pankar
    Only the second method worked for me.
  9. #159
    didi_du_93000's Avatar
    France Paris
    Beter and faster with 0% risk ------>>>> USE Renault DECODER for Fenix 5 and cut immo wire... This ECU can work without immo code inside
  10. #160
    Feb 2011
    Almeria, Spain
    the solution wizz2c
    working perfect.
    someone can yo say these solution is tested in ecu safir - sagem etc??
  11. #161
    Feb 2011
    Almeria, Spain
    Quote Originally Posted by titoun View Post
    Thanks wizz2c,
    This solution works perfectly on SAGEM SL96-9.
    Regards.
    hello tioum
    how is process in the ecu sl96-9
    i have unit ecu sl96-1 will working?
  12. #162
    kugglefischer's Avatar
    In an Ecu
    Quote Originally Posted by dunkler View Post
    28F512 needs to be shortwired right? There are 4 sides each with 9 pins, and both right and left was noted with B and upper side also.
         1    B   9
          | flash  |
    (?)B|          |B (?)
          1    A  9
    BEYWEEN 1 AND GROUND AND 9 AND GROUND
    The difference between men and boyz...Is the price of there Toyz.
    LEACHERS.....DONT KEEP ASKING FOR PASSWORDS
    DONT FORGET TO PRESS THE THANK YOU BUTTON IF MY WORK HELPED YOU....
  13. #163
    Feb 2013
    I need immo off file for Renault Safrane 2.0 16v y96.
    ECu is:
    SIEMENS S113721102 B
    HOM7700868318
    7700103799
    Tried solution2phoenix5, not working.
  14. #164
    Apr 2012
    ECUs, that cannot operate without immobilizer code stored in memory:
    some of FENIX5 for LAGUNA/SAFRANE 2.0l 16V,
    all of SIRIUS32 except for KANGOO 1.4l 16V,
    LUCAS DCU3R, Bosch MSA15.5 and EDC15C3;
    this means that it is need emulator
  15. #165
    Feb 2013
    thanks and how to make an emulyator?
