someone ask me for pinout fenix 5
here it is
here it is
I learn every day and I share my knowledge
almlohe (11th April, 2018), ilen (2nd October, 2016), JotaB (27th December, 2016), martinracing (7th May, 2016)
hi guys,i have one scenic car with ecu:
Siemens
S105300102 D
HOM7700875745
and it wont work with the method described here.when plug in the car immo lamp flashes quickly,and gasoline pump go constantly.car not started and not give sparkle.
some ideas?
best regards
You may have a Fenix 5 with IMMO Type 1, (some Fenix 5 ECU made in 1996 and used even on 1997 cars are type 1) The type 1 can not be decoded with the RENAULT ECU DECODER, but immo off is pretty easy if you have the pin code.
First check immo type this way:
if after ignition-on malfunction indicator lamp(MIL) illuminates for 2 seconds then starts to flash, this is TYPE2 immobilizer system; if after ignition-on malfunction indicator lamp (MIL) flashes immediately, this is TYPE1 immobilizer system.
If type 2 use the renault immo decoder and it will work.
If type 1 and you have the code enter the PIN CODE this way:
1. Depress and keep depressed accelerator pedal fully - injection fault lamp extinguishes. To enter security code use trip computer button on the end of wiper control stalk. This button is called ADAC button.
2. Press the button the same number of times as the first figure of the code, checking injection fault lamp illumination each time the switch is pressed.
3. Release the accelerator pedal: injection fault lamp flashes.
Repeat operations 1, 2 and 3 to enter in succession the three other digits of the code. When the code has been entered the injection fault lamp should be illuminated continuously for 2sec and then must to extinguish.
NOW ECU is decoded and car should start. After car started CUT THE IMMO WIRE (ECU pin 37 for engine 1.4 and 1,6l and pin 35 for engine 1.8, 2.0 and 3.0l) and ECU will work without IMMO FOREVER, IMMO OFF is DONE.
If injection fault lamp flashes, the code is incorrect. Switch off the ignition, switch it on again and repeat procedure for entering code.
Good luck and Best Regards
28F512 needs to be shortwired right? There are 4 sides each with 9 pins, and both right and left was noted with B and upper side also.
Code:1 B 9 --------- | flash | (?)B| |B (?) --------- 1 A 9
sorted out
Could you tell me where is flash in this ECU? Or other solution immo off.
in my ECU there isn't flash. Have someone photo similar to me ecu? Thanks in advance!
