Page 1 of 12 12345611 ... LastLast
Results 1 to 15 of 180
    Junior Member bo0st's Avatar
    Default renault fenix5 im*o
    hello
    need assistance with immo on fenix5 ECU from megane 1,6
    S115300120
    attached file from 28F512
  2. The Following 4 Users Say Thank You to bo0st For This Useful Post:
    Col19 (1st December, 2019), gordonjairo (14th December, 2013), nikos10123 (5th February, 2015), sarigol45 (2nd July, 2016)
  3. #2
    DK Veteran wizz2c's Avatar
    earth
    Quote Originally Posted by bo0st View Post
    hello
    need assistance with im*o on fenix5 ECU from megane 1,6
    S115300120
    try this method first very easy ,post results please
  4. The Following 40 Users Say Thank You to wizz2c For This Useful Post:
    Allmighty (9th March, 2017), almlohe (11th April, 2018), Alphadiag (14th March, 2016), bearheroes (21st October, 2019), capi (16th December, 2013), Col19 (1st December, 2019), elecautocr (21st April, 2014), erdilmen (31st December, 2014), Gabady (11th December, 2018), gordonjairo (14th December, 2013), ian58 (20th December, 2019), konarg (7th October, 2022), line44 (8th November, 2019), lkarag (12th September, 2023), lounadak (12th December, 2023), madbg (7th January, 2015), martinracing (6th October, 2013), mcgywer (17th June, 2015), mehmet44 (21st February, 2016), mohamedkey (24th September, 2013), n599fbm (24th October, 2013), pbn (5th March, 2014), perovuk (15th July, 2014), petan (29th March, 2013), radioman (25th October, 2013), Sabit (20th February, 2017), Salvatar (30th July, 2015), santia6768 (25th March, 2013), sarigol45 (2nd July, 2016), sejoo (24th October, 2014), shtyrya2 (20th August, 2015), skcelectronic (27th August, 2018), speedcar (7th February, 2014), speedy100 (21st May, 2014), sss123456 (15th March, 2017), subas (5th February, 2014), t-ortman (21st May, 2014), TCSTigersClaw (4th November, 2013), thurgau (5th May, 2013)
  5. #3
    earth
    pic of flash location for reference
  6. The Following 19 Users Say Thank You to wizz2c For This Useful Post:
    Allmighty (9th March, 2017), almlohe (11th April, 2018), Col19 (1st December, 2019), gordonjairo (14th December, 2013), ilen (15th August, 2014), k1champion (5th January, 2015), lounadak (12th December, 2023), madbg (7th January, 2015), makura (14th July, 2014), martinracing (6th October, 2013), mcgywer (17th June, 2015), n599fbm (24th October, 2013), Salvatar (30th July, 2015), sarigol45 (2nd July, 2016), sejoo (24th October, 2014), speedy100 (21st May, 2014), sss123456 (15th March, 2017), stivencho (4th January, 2015), t-ortman (21st May, 2014)
  7. #4
    very thanks for reply but i dont understand this section with shorting. pinout is very funny
    "YOU must short-circuit flash when ecu is suply while probe lamp don't blinking.
    Important : Short only side long A with AA (bridge conect pin 1A with pin1AA ANd move start-end-start-end end=9pin )
    PUT SHORT CIRCUIT BETWEEN PIN1 ON A SIDE AND PIN1 ON AA SIDE.
    AFTER PIN 2 A SIDE AND PIN 2 AA SIDE.....TO PIN9"
    can you explain this please? im electronic engineer but this is too much on me...
    maybe understand...after powerup i need to short very fast these pins with pincette or other metal tool?
  8. #5
    earth
    Ok first of all this is bench test method personally i do it while still on car,first cut immo wire to ecu.use the light on dash (engine mngt not red led)for blinking ref.
    one side of the flash is A side the other b side (lets say)
    you have 9 pins either side,so 9 on A and 9 on B, short 1A with 1B then 2A with 2B all the way till 9A and 9B.holding each for at least 2 secs, engine mngt light should go out,car will then start.
    note:you may have to do it more than once before light goes out but believe me it WORKS.
  9. The Following 2 Users Say Thank You to wizz2c For This Useful Post:
    mcgywer (17th June, 2015), Tagne (31st March, 2016)
  10. #6
    earth
    Quote Originally Posted by wizz2c View Post
    updated file with better explaination
  11. #7
    main connector of ECU down or up? witch side is 1?
  12. #8
    earth
    Edited pic for you
  13. The Following 16 Users Say Thank You to wizz2c For This Useful Post:
    gordonjairo (14th December, 2013), k1champion (14th September, 2013), KILL_THE_IMMO (24th January, 2014), kugglefischer (2nd December, 2013), llcoola (3rd December, 2013), martinracing (6th October, 2013), mijatx (8th February, 2014), mohamedkey (24th September, 2013), n599fbm (24th October, 2013), radioman (25th October, 2013), sarigol45 (2nd July, 2016), sejoo (24th October, 2014), SERBAN 70 (21st January, 2015), speedy100 (21st May, 2014), sss123456 (15th March, 2017), ubistvo (3rd May, 2016)
  14. #9
    earth
    method 2 if you require it
  15. The Following 19 Users Say Thank You to wizz2c For This Useful Post:
    Allmighty (9th March, 2017), antwnhszr (10th July, 2014), Autronic (16th April, 2016), capi (1st July, 2014), elecautocr (21st April, 2014), gordonjairo (14th December, 2013), k1champion (14th September, 2013), lkarag (12th September, 2023), makura (14th July, 2014), marco70 (9th February, 2014), OalikO (23rd September, 2013), sarigol45 (2nd July, 2016), sejoo (24th October, 2014), speedy100 (21st May, 2014), sss123456 (15th March, 2017), t-ortman (21st May, 2014), Takinava (9th December, 2014), ubistvo (3rd May, 2016), _estima_ (15th September, 2014)
  16. #10
    so we make something
    the MIL lamp stays on but ECU is on the bench.
    dont have CLIP at home. ill post result tomorrow.
    thanks for now m8.
  17. #11
    earth
    thanks for now m8.
    if you mean reault clip, its not required just plug and go
  18. #12
    yes i know what you mean but i want to erase failure memory and see if is really ok.
    anyway thanks a lot for now.
    ill post results for sure.
  19. #13
    Hi!
    IT WORKS!
    unbelievable but it really works!
    crazy and looks like burning solution but for sure working solution without need of decoder or other device.
    Many thanks m8.
  20. #14
    earth
    Hi!
    IT WORKS!
    Many thanks m8.
    your more than welcome glad your sorted
  21. The Following User Says Thank You to wizz2c For This Useful Post:
    salkapone (15th February, 2015)
  22. #15
    omglol's Avatar
    Jan 2009
    Europe
    Can you explain more exactly what you have to do when you are doing it on a car? Do you have to have ignition ON or OFF? Then you cut the immo wire and then you begin working on the chip? Tnx!
