Results 1 to 9 of 9
    May 2010
    Default Peu Boxer PUMA 4HU injector waveform
    Dear Peugeot/Ford expert,
    I have a Peugeot Boxer with PUMA 4HU engine, ecu Delphi DCU102
    2.0 diesel.
    It crank slowly nearly 270 rpm, fuel high pressure is 470 bar for the first seconds THEN in 20 seconds it drop to 220 bar.
    The target is 370 bar.
    Fuel filter is new.
    Another garage changed the high pressure pump, it's new, and the EGR also is new.
    Starter motor is new, battery is new.
    Sent injectors to test and found one stuck open.
    Bought a new injector.
    Engine crank but no start.
    Please take a look to the injector 4 current waveform while CRANKING and not starting.
    Tell me if it is right or wrong. The current clamp was set to 1mV/10mA and the oscilloscope was set to 30A clamp current.
    This engine use Delphi solenoid injector and the injector resistance is 0.5 ohm for all the injectors.
    Engine will fire only if I use ether and it reach easily 6000 rpm, but it will die as soon as ether is no more applied.
    Van has more than 400.000 km
    ______
    Nov 2019
    Hello!
    1) DCU102 is Visteon, no Delphi.
    2) Check RPM sensor and its wiring. Sometimes it becomes clogged with clutch or starter wear products. At the same time, the number of revolutions of the motor will be visible on the scanner, but there will be no start. This is a feature of such cars.
  3. The Following 2 Users Say Thank You to ilyain For This Useful Post:
    alessioblaupunkt (6th April, 2023), Meat-Head (22nd March, 2023)
    Meat-Head's Avatar
    Tow start. Incase starter motor is giving bad emf
    May 2010
    Sent ECU to check because injector waveform was really poor and waveform was a sinewave, not what you expect for solenoid Delphi injector.
    ______
  6. #5
    May 2010
    P1305 High pressure pump learning. Temporary learning not executed.
    P1306 High pressure pump learning.
    Engine crank only. ECU has been checked by a specialist.
    Engine start and run only with ether, if I remove ether the engine die.
    High pressure pump is new. Got 435 bar while cranking but the pressure will drop to 220 bar in 20 seconds of cranking.
    What will you check now?
    ______
  7. The Following User Says Thank You to alessioblaupunkt For This Useful Post:
    Meat-Head (9th April, 2023)
  8. #6
    gwiazdamb's Avatar
    Aug 2022
    PL EU
    Hi.
    If you haven't checked the signal of the crankshaft sensor with an oscilloscope, do it.
    I had several such faults with a damaged tooth. The oscilloscope shows an incorrect signal.
    There are no DTCs and the whole system is going crazy
    PLEASE PRESS THE " THANKS " BUTTON
  9. The Following 2 Users Say Thank You to gwiazdamb For This Useful Post:
    alessioblaupunkt (6th April, 2023), Meat-Head (9th April, 2023)
  10. #7
    May 2010
    Will check tomorrow. With ether the engine reach 6000 rpm and you can see it in the dash.
    Remove ether and engine die, no current to injector.
    ______
  11. #8
    May 2010
    My first ever CKP shoot. Please comment.
    ______
  12. #9
    gwiazdamb's Avatar
    Aug 2022
    PL EU
    Quote Originally Posted by alessioblaupunkt View Post
    This signal is not valid
    It may be due to the resistance that the engine puts up
    For the second session, I suggest removing the glow plugs or injectors to relieve the engine
    The signal measurement will be reliable with the motor loose
    I propose to extend the signal more in time
    The signal seen on the oscilloscope from the missing tooth vertically and horizontally should coincide
    Time stretching will make it easier observe the signal
    You can always check the pulser teeth after removing the starter motor
    The crankshaft sensor itself is inductive, it happens that it breaks and then it freaks out
    I think you replaced the sensor, if not do it for sure
    And don't forget the camshaft sensor
    Its signal is needed for up-down synchronization. Without it, the injectors have no signal
    Immobilizer I think you have excluded. If you do not see it in the parameters
  13. The Following User Says Thank You to gwiazdamb For This Useful Post:
    alessioblaupunkt (10th April, 2023)
