Results 1 to 3 of 3
    Aug 2019
    Default Help! MK60EC1 ABS long coding!
    Hello. I changed the ABS block, but I can't write long code from the old block.
    old block 1K0907379AD
    the new 1K0907379BJ
    many have replaced with that part number. I have attached pictures with the old block where you can see the long code and the new one where there are all zeros. and the new one has 2 more symbols.maybe you need a suitable other code
    any suggestions?
    mkii's Avatar
    Oct 2008
    same code add 00
    Think Thx an rep buttons !!!
    Aug 2019
    Quote Originally Posted by mkii View Post
    same code add 00
    If I know. because yesterday I found the info and in the morning I already tried it with two 00 and everything is fine. Because the old block is 18bit and the new one is 19bit, I had missed it. But thanks for the reply
