Results 1 to 15 of 22
Thread: KT200 Rework
Hybrid View
    carmageddon's Avatar
    Italy
    Default KT200 Rework
    hi
    if anyone need to rework pcb the component are the same of FG v53.
    here is the list and pics of mine
    KT 200
    U13-U14 : L9613 / E-L9637D
    U20 : HEF4011BT
    U2 : LPC 2119FBD64
    Q11 : ZVP2106 (look for the mounting position because the china copy are wrong)
    Q12 : ZVN2106 (look for the mounting position because the china copy are wrong)
    U18-U22 : ST 485B - MAX485
    U19-U21 : LM393
    U3-U5 : LM1117
    U17 : PCA82C250 for 0-12v obd (PCA82C251 for 0-24V obd)
    U10-U12-U16 : 74HC14D
    U15-U23 : 74HCT125D
    U24 : FT232RL
    RELAIS LITTLE : OMRON G5V-1
  2. The Following 10 Users Say Thank You to carmageddon For This Useful Post:
    biela (17th March, 2023), blackpirate (17th March, 2023), fuzz1 (23rd June, 2023), halofane (22nd March, 2023), karmoranas (18th March, 2023), mexanico1971 (29th March, 2023), Mexaniks (23rd June, 2023), mircea13 (22nd June, 2023), moky (17th March, 2023), stefaudio (30th March, 2023)
  3. #2
    Jan 2019
    Why rework? It works like a charm...
    Italy
    is a china clone…many errors and poor quality in each component…
    Jan 2019
    Quote Originally Posted by carmageddon View Post
    OK, but how does this affect the work of the KT200? Have you found any problems or just find that some elements can be replaced with others? We all want to drive Michelin tires, but most drive Chinese tires, and there's nothing wrong with that.
    Johnsy1998's Avatar
    Oct 2019
    United Kingdom
    Quote Originally Posted by SoftDev View Post
    I'm stealing this quote......
    Nov 2022
    Where did you buy it?
    Italy
    various seller of this tool have european site but this tool are made only in china…i buyed by ecuhelp
    Jul 2018
    what a cheap looking board....u can tell by looking at soldering...its hard to trust a clone like that on a expensive ECU. i wonder if foxflash is same quality...
  10. #9
    what about firmware for mcu KT200
  11. #10
    Italy
    @ Aladinnu : fw is the same but foxflash have not encryption module then maybe can be read…kt200 and other same tools use encryption module…i tried to read with usb to uart but have no comm
  12. #11
    if not a level crp3 you can read mcu
  13. #12
    Italy
    as i wrote, no communication with classic connection uart, maybe foxflash can be readed...kt200 have encryption module...i think not so simple
  14. #13
    so you have to find a foxflash to read the firmware
  15. #14
    Italy
    yes, or maybe a good boy that work in yellow town and want to share it
  16. #15
    Apr 2019
    @carmageddon with this rework did your kt200 obd read/write improve? i can read/write ecu's that use k line with obd protocol, but not a single ecu that uses CAN with obd protocol.
    On the bench no problem with k line or CAN, read and write perfect.
    i dont know if it is an hardware problem or a software problem.
