Page 135 of 243 FirstFirst ... 3585125130131132133134135136137138139140145185235 ... LastLast
Results 2,011 to 2,025 of 3633
Thread: MPPS
  1. #2011
    DK Veteran lolooo1981's Avatar
    Feb 2011
    France
    Quote Originally Posted by Dakta View Post
    Quick question - If you plug in MPPS clone (serial ends in 234) 3.0.2.37 into internet connected computer, does it block automatically?
    Mpps software is not connected to internet, no problem, but if you really want to block it, run it simply to 3.38 version
    Best regards
    Original Kwp2000+ and other...
    No stress for all !
  2. #2012
    Haha cheers for that.
    Got a mpps box - using the supplied software - 3.0.2.37 but it wouldn't connect to one of my vehicles so I wondered if it had 'automatically' updated itself over the internet (I didn't manually attempt to update it, but wondered if being connected to internet permitted an automatic download).
    I shall assume then that it's the vehicles fault and try it again
  3. #2013
    DK Veteran mishu_b's Avatar
    Land of Choice!
    No automatically update posible up to now.
    what case has your tool?
    atb
  4. #2014
    It's the silver box. It hasn't been used before so all I can assume is it's dead on arrival (DOA).
    No attempt has been made to update it, though it has been plugged into computers that have internet access.
  5. #2015
    Feb 2011
    France
    Chineese clone...mine not work in arrival too...Serial 234?
    If yes try to update with cracked version of Scary maybe help you.And ever...use it at your own risk...
    Best regards
    No stress for all !
  6. #2016
    Serial 234?
    That's the one
    I think i'll just buy a later unit. These sound way too problematic.
  7. #2017
    DK Veteran rsibiza's Avatar
    That's the one
    I believe you will encounter 100% same problems,with newer china clone.
    The only good working mpps clones come from europe,they work with genuine sw,dont need any crack,loader which allows unit to work even with FFFFFF or 000000 serial...
    If u want start business,buy good euro clone or original unit,but lot customer with original ones ran away from...who know why ...hehe
  8. #2018
    Moon
    not really ... most of the Amt customers sold the v8 and v9 genuine tools and are working with clone v5 which is a lot better.
  9. #2019
    Ironic, isn't it really!
    But yeah I've heard of no-end of problems with the genuine tool when updated...what a put off. They're not exactly bust-your-balls expensive are they.
  10. #2020
    info my mpps obd lead v5.08 3.0.3.38 read/write bmw e46 320d edc16c31. and 118d edc16c35 with no problems
  11. #2021
    Jun 2011
    i updated my mpps to V9 from V8 and now i cant add the drivers it only adds the interface as a human interface device
    and i cant update the firmware since device is not found. i tried on WinXP and XP Pro
  12. #2022
    Top Poster lulu2003's Avatar
    Jun 2011
    Quote Originally Posted by riddler View Post
    auto checksum working fine?
    did you put 14v on the car as mentioned?
  13. #2023
    Feb 2011
    Hello everyone.
    There is a problem.
    fiat doblo 1.3 jnd with ECU magnetti marelli MJD6F.D6
    MPPS 5.0.1.10 on a line not yet read.
    identifikatory not read, too.
    CAN identifiers to read, but read the flash button is not active.
    He opened the box and read BDM100. (Chinese clone)
    tab, single, and after the export has size 518 KB flash and eprom 4 kb.
    As I understand it's not a full size flash
    how to read the full size flash and what size should be?
    magnetti marelli
    51862582
    MJD6F3.D6\HW04P\3645-D670
    SDE85HPEU4UEG0
    8183YF2K
    D032
    MJDF3.DGBC010
    1853A
    AB15
  14. #2024
    checksum working fine, voltage 1210 no problems
  15. #2025
    ALGERIA
    the flash is in processore
    the size shuld be less than 500Ko
