Page 140 of 243 FirstFirst ... 4090130135136137138139140141142143144145150190240 ... LastLast
Results 2,086 to 2,100 of 3633
Thread: MPPS
  1. #2086
    yellowstilo's Avatar
    i just tested it , had to reinstall the drivers manually and to update the firmware -unfortunately it still shows 100% cpu usage / ecu not found...
    Could it be possible my (rather old ) Dell D610 is too slow for these newer versions?
    I run Windows XP /sp3 , 1,73 gHz / 2mb cache memory, 1 gb memory.
    I connected a multimeter to the K-line and see a few voltage drops when i press ecu data so i guess MPPS tries to connect to the ecu...
    Unfortunately i don't have a newer/faster laptop to test this version, i will wait for other comments...
  2. #2087
    exxl's Avatar
    Jun 2009
    Bosnia-Herzegowina, Bos. Krupa
    on what ecu you are trying to read out the id ?
    if it is on k-line it could be that lm339 or hc32d is defect,
    if it is on can then check sja1000t and the smd 8 pin driver 2551.
    btw. i just tested my mpps with 10.0.2.3 version on vag edc16u34 and it works very well read and write, will tonight try on my other car audi a4 with edc15, will let you know about it.
    regards
  3. #2088
    i try to read a IAW5NFT1 ecu from a Fiat Stilo (K-line) - worked without problems with a alu clone with v5 upgrade chip.
    I will try to replace the two chips, will post the outcome here.....
    thanks for your help !
  4. #2089
    DK Veteran mishu_b's Avatar
    Land of Choice!
    have your tool worked out before update?
    atb
  5. #2090
    Quote Originally Posted by mishu_b View Post
    atb
    Hello, no it never worked from the start - i bought it as non-China v8 , upgraded to v9 on request of the seller, now upgraded to v10 but it just don't connect to the ecu while a cheapo v5 clone works without any problem...
    It does show all tool and software/firmware data so i guess the mcu is programmed o.k. (confirmed by updater)
    I will replace the two mentioned chips and hope this will solve my problem.
    I also just ordered a second alu clone v5 as back-up, it's just 36.50 euro including free shipping from China at the moment....
    If i can repair the v10 tool i will use my ordered v5 chip to update this clone as i expect it will be a v3 with the v5 patch...
    to be continued....
  6. #2091
    Jul 2011
    France
    the same problem for me.
    i have a european v8 clone and works with no problems with the v8 software.
    but with the v9 my mpps doesn't work with my golf5 edc16u1
    and it's the same with the v10!!!! he doesn't work.
  7. #2092
    ipejasinovic's Avatar
    Jun 2009
    Bosnia & Herzegovina
    From which side of Europe is your device?
    Galletto 2012 v54 full with JTAG and Mini available
    Big Stars never dies:
    Colin McRae (1968 ***8211; 2007)
    Richard Burns (1971 ***8211; 2005)
    Georg Plasa (1960 - 2011
  8. #2093
    Quote Originally Posted by ipejasinovic View Post
    Mine is from Belarus....
  9. #2094
    DK Veteran lolooo1981's Avatar
    Feb 2011
    France
    Someone test on edc16C9 ?
    Original Kwp2000+ and other...
    No stress for all !
  10. #2095
    scarymistake's Avatar
    Apr 2009
    Europe EN
    Quote Originally Posted by lolooo1981 View Post
    who test this version ?
    The problems are gone ?
    Mine is also from Belarus purchased as a v8
    i test it with v8 reading and writing ok edc15 and edc16 psa
    v9 no reading and writing edc15 and edc16 psa
    v10 reading and writing edc15 ok
    Tomorrow I try EDC16 and i let you now
    look here more info
    http://forum.amtcartech.com/index.ph..._next=prev#new
  11. #2096
    DK Veteran elchip's Avatar
    EU
    Post
    V9 have problem K-line but CAN work.
    V10 in testing from me too.
    Will raport
    Regard's
    [I]Automotive Electronics Solutions
    Mercedes-Benz Reverse Development Engineer ...
    Mercedes CFF 2010-2017 CFF all models all modules
    Vediamo help flashing over teamviewer ...
    JLR SDD online + offline ...last official ...
  12. #2097
    Jul 2011
    France
    mine is from uk
  13. #2098
    Dobermann's Avatar
    Germany
    hello i use now V 10.0.2.3
    for me nothing works !!
    i tryed to read ME7.5 audi s3 and seat leon
    no communication !! no id no read nothing !!
    thats really sad !!
    my hope was that the problems are gone with the new version !!
    but that was dream
    now K line will not work !! i try can TFSI Golf tommorow !!
  14. #2099
    Jul 2011
    France
    Quote Originally Posted by Dobermann View Post
    thats really sad !!
    but that was dream
    for me just id work but read doesn't work on golf5 edc16 u1 kline.
    work with v8 but doesn't work with v9 and v10
  15. #2100
    Dobermann's Avatar
    Germany
    Quote Originally Posted by zlatinou View Post
    i think V10 is the same trash like V9 !!
    but with V9 i could read me7.5 with a little trick
    i make ID with me7.1 than i switsh to me7.5 and click read !!
    that was working on me7.5 with V9 now with V10 nothing !!
    i dont know what they are doing in the Factory but its trash too for the moment !!
    nothing works right !! i think the drivers are the problem !!
    what windows do you use ??? i use win xp prof 32 bit on win2000 MPPS is not working !!!
