Page 141 of 243 FirstFirst ... 4191131136137138139140141142143144145146151191241 ... LastLast
Results 2,101 to 2,115 of 3633
Thread: MPPS
  1. #2101
    soundnavigator's Avatar
    Sep 2010
    If you have original tool, send log file to AMT to resolve the problem in next update ... maybe.
    Best regards.
  2. #2102
    DK Veteran mishu_b's Avatar
    Land of Choice!
    Quote Originally Posted by yellowstilo View Post
    Hello, no it never worked from the start - i bought it as non-China v8 , upgraded to v9 on request of the seller, now upgraded to v10 but it just don't connect to the ecu while a cheapo v5 clone works without any problem...
    It does show all tool and software/firmware data so i guess the mcu is programmed o.k. (confirmed by updater)
    I will replace the two mentioned chips and hope this will solve my problem.
    I also just ordered a second alu clone v5 as back-up, it's just 36.50 euro including free shipping from China at the moment....
    If i can repair the v10 tool i will use my ordered v5 chip to update this clone as i expect it will be a v3 with the v5 patch...
    to be continued....
    Q: when you try to "ECU ID" - do you get the message "ECU not found"? - (for K line)
    if yes - change the LM339 and HC device - maybe it will work!!!!
    Q: for CAN - what message do you receive for "ECU ID"?
    atb
  3. #2103
    yellowstilo's Avatar
    Quote Originally Posted by mishu_b View Post
    atb
    yes, i get message "ecu not found" upon "ecu id" request on K-line with version 8,9 and 10 - i will replace both chips as suggested and post te results.
    Same test with simple alu clone with v5 update chip works o.k....
    I did not test it on CAN because i only use the MPPS for my private car (Stilo 1.6 with K-line for diagnostics and reprogramming)
    thanks for your help...
  4. #2104
    scarymistake's Avatar
    Apr 2009
    Europe EN
    If you need it the drivers from v10
  5. #2105
    exxl's Avatar
    Jun 2009
    Bosnia-Herzegowina, Bos. Krupa
    can confirm now that vag edc15 is working too, did not write it but id and read goes smoothly so i think the writing would go too.
    for me v10 works good till now
  6. #2106
    Apr 2009
    Europe EN
    Quote Originally Posted by scarymistake View Post
    Mine is also from Belarus purchased as a v8
    i test it with v8 reading and writing ok edc15 and edc16 psa
    v9 no reading and writing edc15 and edc16 psa
    v10 reading and writing edc15 ok
    Tomorrow I try EDC16 and i let you now
    look here more info
    MPPS Version 10 available from the AMTcartech website for downloading
    edc16 psa working reading and writing car is runing
    edc15 psa working reading and writing car is runing
    me744 psa not working but also not working on v5 and v8
  7. #2107
    DK Veteran lolooo1981's Avatar
    Feb 2011
    France
    anyone test on opel edc16C9 ?
    Original Kwp2000+ and other...
    No stress for all !
  8. #2108
    Test anyone 7.6.2 opel? V5?
  9. #2109
    Jul 2011
    France
    Quote Originally Posted by e.t. View Post
    i have read bmw 5series 525d e60 year 2006 edc16c31 with no problem with the version 10
  10. #2110
    DK Veteran elchip's Avatar
    EU
    MB EDC16C4 work perfect on K and CAN V10.
    Regard's
    [I]Automotive Electronics Solutions
    Mercedes-Benz Reverse Development Engineer ...
    Mercedes CFF 2010-2017 CFF all models all modules
    Vediamo help flashing over teamviewer ...
    JLR SDD online + offline ...last official ...
  11. #2111
    atb
    Can you explain this, i cant follow you?
    LM339, HC Device..??
    i have also "ECU not found" with Me7..
    i use v10, orig. tool
    many thanks
  12. #2112
    Dobermann's Avatar
    Germany
    Quote Originally Posted by miggi View Post
    many thanks
    hello do you use original mpps tool ??? i too !!
    i tryed me7.5 but always ecu not found or no information
    id - read/write >>> will not work
    with V9 it was possible to read/write with the my little trick
    but now nothing works on me 7
    what car did you try ???
  13. #2113
    Sep 2010
    People, write for all this problems in AMT forum and maybe upload the log files.
    Best regards.
  14. #2114
    many thanks
    LM339D and 74HC32D are two smd chips inside your MPPS - you can replace them by desoldering and resoldering .....
    I'm still searching for a supplier who sells small quantities.
  15. #2115
    @Dobermann
    i tried Audi S3 Me7.5 (29f400)
    with byteshooter, galetto etc. no problems...
