Page 145 of 243 FirstFirst ... 4595135140141142143144145146147148149150155195 ... LastLast
Results 2,161 to 2,175 of 3633
Thread: MPPS
  1. #2161
    DK Veteran lolooo1981's Avatar
    Feb 2011
    France
    Quote Originally Posted by majorahole View Post
    Thanks, that's v5 only? Or will the older version work too? With checksums too?
    I don't try with V8 or V10,But with V5 and if this is Med9.1,yes,checksum is calculated by the program.Other med9.5 you need to calculate checksum.
    Best regards
    Original Kwp2000+ and other...
    No stress for all !
  2. #2162
    Feb 2011
    France
    try to resolv problem of edc16C9,someone have more info ?
    No stress for all !
  3. #2163
    France
    Quote Originally Posted by lolooo1981 View Post
    I read and write seat leon TFSI Med9 without any problem with V5 too,i think for this car you can.
    Best regards
    The version V5 is really stable....
  4. #2164
    hi! Had anyone ever problems with EDC15 A2 1.4tdi?
    I could not read it!
    5.0.1.13 is the mpps software
  5. #2165
    DK Veteran Amine13's Avatar
    Quote Originally Posted by e.t. View Post
    Hello; are you sure it's EDC15 ?
    Regards.
    Just start, and all come itself!!!!!!!
  6. #2166
    Feb 2011
    France
    In many old car Vag group fuse remove is needed to access to ECU perhaps its the same way...
    Best regards
    No stress for all !
  7. #2167
    France
    Use the galletto 1260 for all EDC15....
  8. #2168
    I remove the fuse but its not reading.
    I take the galletto and it works fine
  9. #2169
    ALGERIA
    USE THIS OPTION
    with MPPS you don't need to remove fuse for vag edc15
  10. #2170
    Ok thanks, i will test it!
  11. #2171
    Sep 2010
    since i use mpps i never have to remove fuse or anything for vag edc15 and the recover work well .
  12. #2172
    May 2011
    Illinos
    Quote Originally Posted by stk90 View Post
    Interested to know me too, I remap a Fiat Grande Punto and I think it works only this cable loss.
    If you know where I can buy it there would be really grateful!
    you can buy this it works well. thanks...
  13. #2173
    Dec 2010
    I have also problem on some 1.9TDI from 2000, 2002 with EDC15, on newer cant do Ecu Id with v5 clone
  14. #2174
    Sep 2010
    Quote Originally Posted by eduardo74 View Post
    edc15 vag confirmed to work flawless on V3 V5 and V8 on clone with original or patched software.
    if you get trouble perhaps your clone is bad
  15. #2175
    Sep 2010
    Quote Originally Posted by nicole99wu View Post
    you can buy this mpps clone, it works well. thanks...
    too expensive.
    you can buy good V3 clone for 40usd and upgrade it yourself with patched V5
