Page 155 of 243 FirstFirst ... 55105145150151152153154155156157158159160165205 ... LastLast
Results 2,311 to 2,325 of 3633
Thread: MPPS
  1. #2311
    Oct 2011
    Default mpps opel
    Is the mpps actual a good choise for most of the opel cars or does somebody recommend something else ?and does he open up the k-line automatic or do you still need to open it manually ?
  2. #2312
    ecutuners's Avatar
    Apr 2011
    United Kingdom
    Quote Originally Posted by Multipla View Post
    See this link::::::::> Bootloader_V000 C8051F340 USB HID mode , contains instructions for use, the firmware c SCM www.pudn.com
    So you know what I am talking about just who is in charge and gives me some discomfort.
    here you go if you make something of it please share the result
    Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
    ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
    EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
    DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
    Professional Engine Software Development
  3. #2313
    Multipla's Avatar
    Turin,Italia
    certainly if I can do it from the community as a whole must enjoy so speculer? nobody on this thing which seems scandalous, a select few make money and the hapless spend a lot of money. I nn I admit everything, I write this to all those people who do not understand the spirit of the community. Indeed thank you in advance you are really a person. Tanks //// ecutuners \\\\
  4. #2314
    ITA
    i post again a question...i have block in writing an edc16c35 bmw 2006 with v5 mpps clone (made in eu).
    i have select 3.0l edc16c35 , and c31, but both block in writing..it erase the flash and not start to writing...
    my quesiton is: the new driver of V5 mpps (3.5d Edc16c35) is reserved for 535d and 335d motor (272hp and 286hp)???
    3.5d is strange: bmw hasn't got any 3500cc , but only 3000cc biturbo (535d and 335d and X5 3.5d )
    for write my 535d 2006 edc16c35 272hp what driver i must select?
    if i select 3.0L with 14v block always my ecu..3.5d i don't had tried
  5. #2315
    Multipla's Avatar
    Turin,Italia
    Yesterday I made an accident with the car, a ****er came against is I destroyed the machine. you have to forgive me, but nn psso\r follow some work for mpps. However, responding to W and E Kdgl your file may be corrupt or devileggerlo in the boot with ecu disassembled. Then mpps on ecu directly and stabilized power supply at least as regards the ecu pins +
  6. #2316
    ITA
    no my file read of 1mb is ok...is the same file of bdm read
    my mpps not blocking in writing but in erase operation , before writing
  7. #2317
    Multipla's Avatar
    Turin,Italia
    write in ricovery mode and stabilizes with a booster battery machine.
  8. #2318
    ITA
    recovery mode not work because half of M58 flash are erased!
  9. #2319
    Multipla's Avatar
    Turin,Italia
    try putting in the original and if you say that the cks is not fair.
  10. #2320
    Default MPPS V10
    Hi folks,
    i cant get my V10 Clone working ! everytime when i read my Golf V 1.9 TDI in 1.9 TDI EDC16U34 Mode it stops on the half way 10%-60% and then disconnect !
    But if i read it in 2.0 TDI EDC16U34 Mode it completes 100%
    Then i tried to read out the Car of my Brother: Laguna 2.2 DCI EDC16CP33 but it simply cant read anything .. seems like it passes the security but then ... nothing !
    I tried to change the speed settings ...
    Does anybody got an idea ?
  11. #2321
    DK Veteran lolooo1981's Avatar
    Feb 2011
    France
    Edc16cp33 have many problem.
    For edc16U34 i never had any problem.
    Had you check for DTC ?
    Or try in other software version like V5
    Original Kwp2000+ and other...
    No stress for all !
  12. #2322
    I already tried the Laguna with V5 but it doesn?t work aswell !
    thats why i upgraded to V10
    I get DTC?s if i try to read out the Laguna !
    I ask my self why the Laguna is listed in MPPS if its not working.
    .....hmmmm
  13. #2323
    Feb 2011
    France
    Not for Edc16CP33 but for edc16U34.
    Edc16CP33 laguna DCI 120 have also many problem
    Many car on the list of mpps don't work.
    Try with another tool.
    No stress for all !
  14. #2324
    Dec 2010
    Toyota is not listed? Anyone have experience with Bosch EDC15/EDC16 from D4D engines?
  15. #2325
    OK !! can you recomend me a cheap Tool that works for the Laguna?
    THX for your help !!
