Page 159 of 243 FirstFirst ... 59109149154155156157158159160161162163164169209 ... LastLast
Results 2,371 to 2,385 of 3633
Thread: MPPS
  1. #2371
    lee_hdi's Avatar
    Sheffield
    Just bought one of these and soon as I installed it it came up with "This unit is a Clone", does that mean I can't use it?
    I had a search and can only find this - http://webcache.googleusercontent.co...&ct=clnk&gl=uk
    But can't see a real answer.
    Will the unit work or not?
    Don't let failure go to your heart, don't let success go to your head.
  2. #2372
    ALGERIA
    instal the cracked v5 of scary,it will solve your probleme
  3. #2373
    moky's Avatar
    Behind you
    hi
    i have an audi A5 3.0 tdi edc17 cp 14 (2007) to do ,someone have tested on this car? (last version 12 of mpps)
    thx a lot
  4. #2374
    DK Veteran lolooo1981's Avatar
    Feb 2011
    France
    Quote Originally Posted by moky View Post
    hi
    thx a lot
    I have tested Edc17CP14 on audi A5 and VW Eos and with no problem but in V8.0.2.10, you need to calculate checksum.
    Best regards
    Original Kwp2000+ and other...
    No stress for all !
  5. #2375
    UK
    i see that ecu tuner is blagging it with old experiences that didnt work,,,,,,,like my signiture says---beware of blaggers n bullshitters......
    MAGPRO X17--AT-200--SCANMATIC BENCH--PCMFLASH--MITSUBISHI MUT-III---OPENPORT 2 MMC FLASHER
  6. #2376
    moky's Avatar
    Behind you
    Quote Originally Posted by lolooo1981 View Post
    Best regards
    thanks for this report
  7. #2377
    ALGERIA
    Best regards
    what do you mean by "tested"?
    read dump and flash the same dump that you had read?
    or
    read dump and flash a modified dump ?
  8. #2378
    Feb 2011
    France
    Quote Originally Posted by grinovsky View Post
    or
    Just read it for the moment, not write.
    Regard
    No stress for all !
  9. #2379
    Moon
    tested clone v12 with 2 x edc17cp14.
    Flashed OK, customers happy. Flashing time I think is less now than in previous version. CPU usage was 99%.
  10. #2380
    moky's Avatar
    Behind you
    thanks bazare
  11. #2381
    Feb 2011
    France
    And what is good for checksum calculating ?
    No stress for all !
  12. #2382
    i thought you can't do EDC17 over OBD due to the RSA?
  13. #2383
    ALGERIA
    cks is calculated by mpps becose it's partial read
  14. #2384
    Moon
    I use x17 sw + genuine tool for checksum after winols processing. X-17 can flash this edc17cp14 but in boot mode not by obd. edc17cp14 does not have RSA protection.
  15. #2385
    ALGERIA
    Quote Originally Posted by bazare View Post
    I use x17 sw + genuine tool for checksum. X-17 can flash this edc17cp14 but in boot mode not by obd.
    no,this is wrong
    with edc17 mpps read partial read and flash partial dump,mpps don't write the same bit when flashing,but when it write a different bit mpps correct cks then write 2nd different bit then correct cks and continus like this at the end
    mpps correct cks in the chip when flashing
