Page 180 of 243 FirstFirst ... 80130170175176177178179180181182183184185190230 ... LastLast
Results 2,686 to 2,700 of 3633
Thread: MPPS
  1. #2686
    DK Veteran mishu_b's Avatar
    Land of Choice!
    Quote Originally Posted by iori97440 View Post
    I've ordered one, but it is not arrived yet. So recovery with mpps is not as "easy" as people says ?
    you are one of the very first ones which says that about recovery with MPPS tool.
    I had done many recovery with MPPS (not alu box) 100% succeeded.
    atb
  2. #2687
    Jan 2012
    In fact, a lot of people said that it is very good. I think I had no luck... Maybe i'll buy a new one ! Thanks you guys for the quick replies !
  3. #2688
    mpps tested in alu box in recovery VAG -edc15p -dash fuse unplug and then works well
  4. #2689
    UK
    to be honest-i would remove the ecu...the ibiza is a doddle to remove.then wiring it up on the banch,and have ago there.....this should be easy...
  5. #2690
    Jan 2012
    it's what i've done...
  6. #2691
    UK
    anyone done a read and write on the bench with vag edc16 ecu.ive made a harness up,just had a play,reads fine,but i get a error when writing---"CONDITIONS NOT MET"
  7. #2692
    z786's Avatar
    10 Steps Ahead of You
    immo is active, remove eeprom and try again
    "I always tell the truth. Even when I lie"
    "We Taking Over, One City At A Time"
  8. #2693
    UK
    thanks z786-so i guess in the car the immob is seen as being 100% ok,
  9. #2694
    z786's Avatar
    you can also try to do immo off and leave eeprom on and then try
  10. #2695
    UK
    cheers,will i be able to use a clip and read the eeprom while is on the board,or is it better to remove eeprom and read that way...
  11. #2696
    z786's Avatar
    better to remove and dont forget to save original data
  12. #2697
    UK
    appreciated-cheers
  13. #2698
    Aug 2011
    germany
    Default Mpps V12 update to V15 new version
    Quote Originally Posted by lolooo1981 View Post
    What is new in V14 version if someone have it ?
    Maybe someone can post it here...
    Here is V12
    for update to V14.. (V15 newes version) press in mpps screen update soft...it will update by internet
    there will be no new download for the MPPS
    only in the software you can upgrade
    !! after update to V15 it will not start...
    but V12 will start and run
    V15 not how no solution please share like me
  14. #2699
    Aug 2011
    germany
    MPPS V12 europ version works 1000% super fine...
    i have tested on more than 21 cars now
    only BMW need to put battary to over 14volts
    but now guys...please find solution for V15!!!
  15. #2700
    I had a little pause from this stuff,so want to ask here what are the last sw.wich work on hw.8.0.6?
    Best regards
