Page 185 of 243 FirstFirst ... 85135175180181182183184185186187188189190195235 ... LastLast
Results 2,761 to 2,775 of 3633
Thread: MPPS
  1. #2761
    psico's Avatar
    Quote Originally Posted by macxlulu View Post
    last write mpps v12 edc15c3 (307 2.0 hdi) at 70% of the time out error message
    of course car not start
    well it was not EDC17
    Mpps is no good for this ecu, i read and write more with galletto clone and 0 problems.
    You solution, is conect pp2000 and erase dts , conect mpps, and select mode slow or recuperation, you can write and no problems.
  2. #2762
    my mpps is very old in version 3.0.27.working good
    5.0 -working good ppd ,edc16 etc -no problem
    after the upgrade to v12 problems begin
    Generally I rarely use but he was surprised that with such prehistoric ecu interrupted communications
    There was no problem because desolder flash
  3. #2763
    I also tried to write dump to EDC15C2 307 2.0 HDI by MPPS v5 but no success - error after erasing flash. Read was OK. Recovery mode wasn't work.
  4. #2764
    I can't find last of version MPPS downloading link from AMT webpage. Where i can find or who can give download link about last version MPPS(15)?
    Best Regards,
  5. #2765
    moky's Avatar
    Behind you
    hi
    someone had tested v12 on twingo rs ?
    Thx
  6. #2766
    Dec 2010
    Default Which version is most stable?
    I am in doubt, if I shoud buy MPPS clon. I need to do EDC16c8 Alfa/Fiat and EDC16c34 Renault CAN. Did anybody try these ECUs? Which sw version is the best? Thanks for advices.
  7. #2767
    Hello
    V12 work good on this ecu?s.
    Tested with my cable and work fine.
  8. #2768
    Dec 2010
    Hello
    someone had tested MPPS v12 on VW Passatt EDC 16?
    Best Regards
  9. #2769
    Quote Originally Posted by sarkann View Post
    mpps v5 edc16c8 , multiple times no problem, just make checksumm before with winols
    read time 50minutes, write 2-3mins
  10. #2770
    Mar 2012
    Have you people changed the Cylabs to 344 in the MPPS V12? have seen any difference with old Cylabs or new 344 Cylabs?
  11. #2771
    Dec 2010
    Hello can you help me please.I have DigiProg OBD flasher and i have VW adapter which i must directly connected on the ECU.I think this is adapter for VW EDC 15.Can i with this adapter read write VW EDC 15 ECU?
    This adapter connects on OBD flasher.Can i read write all VW EDC 15?
    Best Regards
  12. #2772
    DK Veteran glk96000's Avatar
    Free
    Eh guy
    it s a post for MPPS only
  13. #2773
    Dec 2010
    Sorry,I see that there are a lot of people with experience so I thought that I would help someone.
    I apologize to everyone.
    Best Regards
  14. #2774
    Dec 2010
    Someone had tested MPPS v12 on Opel Corsa D 1.4 16v?
    In advance thanks
    Best Regards
  15. #2775
    Top Poster lulu2003's Avatar
    Jun 2011
    Quote Originally Posted by RaraK View Post
    med9.1 bricks ecu, bad checksum routine on v5 cracked clone.
    100% sure or only one case?
    there were also successful reports here.
    btw: what about the time needed to write these 2.0l AXX,BPY,BYD?
