Page 25 of 243 FirstFirst ... 1520212223242526272829303575125 ... LastLast
Results 361 to 375 of 3633
Thread: MPPS
  1. #361
    Top Poster + ka-pa-za's Avatar
    Quote Originally Posted by rsibiza View Post
    ??I have original MPPS,and updating from 1xxx to 3xxx was only getting a code from them,install new soft received by mail and update FW...did not need send back my interface??
    so you have the key to make all s-mps first gen clones work with new software.... ;-)
    i know 6 people that had to send back first gen mpps and recived back new design cable. (explain was that the hardware was also updated)
    i try to make gsmtech cable and viaken box work with parts of my clone. and software works. but not possible to write the ecu's that came later in the carlist.
    Not possible to use new dump in old (erased) ic.
    gsm tech cable are legs cut off from ic. on my clone. they are connected if i desolder them i have same problem. can't write latest added ecu's. so it needs those connections to make it work.
    ps; to make sure, i did not cut, they are sold like that.
    I think more easy to look for good clone, than put a lot efford in upgrading old clones. Always look for clone sold with latest software. Big chance they are update proof.
    clones sold with old software can't be upgraded. if so the seller would have done that to sell "latest version"...
  2. #362
    DK Veteran rsibiza's Avatar
    Unhappy
    Quote Originally Posted by ka-pa-za View Post
    My ori and clone are different from yours. Its in a box with separate usb and OBD connector,not all in one...like ori KWP2000 once...
    Only difference i see,some parts changed...
    Example clone have clock...ori one have some blue 3 pin i donno what(sorry),and some resistors other values...
    Still checking all differences...
  3. #363
    Quote Originally Posted by jjg47 View Post
    hello, the old mpps with 1.0.0.100 version can be update until version 3.0.0.17, after all updates will block the interface so dont try it.
    to update:
    after having the 1.0.0.100 instaled (never install other version first time it will block)
    1- install the version 1.0.2.8
    2- change pc date before 02/2010
    3- plug the usb cable and see if above it make the firmware update (install driver if asked).
    4- you can try read a ECU
    5- disconect usb smps
    6- install V3.0.0.17
    7- conect cable usb and run software
    8- it will update firmware
    9- in the screen it will ask a code, copy the code that is in this screen
    10- close the software
    11- open the software
    12- put the copied code in the ask code.
    13- try to read
    note this update is not alowed by the chinese supplier, if the smps block the waranty is not covered.
    The 3.0.0.17 version is more instable then 1.0.0.100 I put here this info but not recomend enyone to do this update.
    Theres a new clone for mpps with new hardware, it cames directly with V3.0.02.19 software.
    I have 2 old smps blocked, I need also information for reprograming them.
    Hope i help with this.
    Hi Guys.
    I updated now from Viaken MPPS V1.0.0.100 to
    1.0.2.8 made FW update....try read ECU edc15 at table NP
    3.0.0.17 made FW update..try read write ecu at table NP
    Then i have tryed to update to 3.0.2.14 and 3.0.2.19,but get asked that code..which has to be copied and close soft,reopen and paste code...but for 3.0.2.14/19 this does no longer work...how to modify the code to get MPPS starting?
    THX in advance
  4. #364
    @kapaza
    Do you know where to find maybee something like KeyGen for this activation code...
    I m sure once i have this code,it will work,as i connect the interface it does not show FFFFFFFF but always his serial number.
    Only shit is this code
    THX in advance
    BTW if somebody can help me with this code,i will put the proof if succeed,bill of buy on viaken and printscreen of(maybee) working MPPS clone V1.x.x.x to 3.x.x.x
  5. #365
    i know someone who has.
    (NOT ME! Dont fill my pm with questions...)
    But i'm sure it will not be for free. soryy...
  6. #366
    Btw, this morning i made scirocco tdi (edc17) work with mpps and bootcable.! works like a charm. no resset after vas connection.
    first attempt a few weeks ago (straight to obd) was bad. but now with bootcable on the bech, it works super.
    184hp and 390Nm on the dyno...
  7. #367
    what do you mean with bootcable ? please can you explain...
    BR
    Eddi
  8. #368
    Top Poster naruto12's Avatar
    Portugal
    Yes, someone its updating old mpps to new version, but its not only the key that they need to update...
  9. #369
    Quote Originally Posted by naruto12 View Post
    i also explain here. recognizing software is one thing. making s-mps flashing edc16c39 or edc17 is another.
    write will fail.
    i tryed the mcu from good clone om gsmtech cable and on viaken clone. Not working. software yes. write saab 93 ecu NO. software say ok. write stop on 9%
    mcu in good clone write 100%
    so mechanical/electrical restriction is more important than software.
    just hack the software so it don't need cable serial should be more easy to do than dumping the mcu.
  10. #370
    3 pin blue is resonator.
  11. #371
    Top Poster Metin's Avatar
    DK
    please send me connection diagram for this bootcable
    br
    Metin
  12. #372
    Aug 2010
    I think you meant software
  13. #373
    ipejasinovic's Avatar
    Jun 2009
    Bosnia & Herzegovina
    Hi viaken, nice to have you here, ofc, if you are owner of Viaken.pl: Viaken - elektronika dla motoryzacji store, but take care since public advertising is forbidden etc... So, we don't wanna you get banned. I didn't say that you have make advert in your first post, I just want to tell you rules of this board, since a lot people doesn't read it.
    Galletto 2012 v54 full with JTAG and Mini available
    Big Stars never dies:
    Colin McRae (1968 ***8211; 2007)
    Richard Burns (1971 ***8211; 2005)
    Georg Plasa (1960 - 2011
  14. #374
    Aug 2010
    no my names Ken and I came via google, was a nice name to use
  15. #375
    Portugal
    Quote Originally Posted by viaken View Post
    Ok, sorry...
