@mihaiservice
You seems to be lucky, because a lot people try to update 41323234 and all they get is: ECU Not Found.
@mihaiservice
Galletto 2012 v54 full with JTAG and Mini available
Big Stars never dies:
Colin McRae (1968 ***8211; 2007)
Richard Burns (1971 ***8211; 2005)
Georg Plasa (1960 - 2011
maybe
anyone it know wich sw are the last ? or someone make jokes about last sw![]()
4.0.1.9 is latest.
But do anyone sell clone that is working with 4.0.1.9 ?
BR
KP
EDC16C31 with 3.0.2.31 flashing data 1344 kB and with
3.0.2.37 1920kB?
Software problem?
good day all. i have purchased mpps v 3.0.2.38. i have diconnected the antivirus. installed the software. tried to read 3 gti golf 5's...1 T5 2.5 bus... 1 golf4 gti... i cant seem to wake up the ecu. the gti's are med9.1's..they are listed. to install the program is fairly easy. how would i know if it is a software problem or a hardware issue. thanks members.
post a print screen with your mpps sofware, and cable inserted in ths usb port![]()
MPPS 3.0.2.37 is last working version...if blacklist serials are mod in ini file they no more recognised as clone and dont show FFFFFFFF...but dont wake up any ecu
This is explained lot of times,you are not the first and not the last...which will encounter this phenomen..
thanks rsibiza. should i then load the 2.0.2.37 version. i was told by my supplier to load the 2.0.2.37. thanks.
sorry i was told to load the 38. tried reinstall version 37. no luck, tried waking up golf5 edc 16 u1. not communicating.
if 3.0.2.37 is not working you have bricked it and needs to be reflashed
thanks bazare. how do one do that. will i be able to do it myself. do you also use bdm100. will clone work on med9.1 ecu. do i need to remove the ecu and open it up to read the flash. thanks.
