no sorry i lose not my time send my flash
and i solved problem
please i need only flash
( no addys to be posted )
Give up at right time. You can't make dump that way. MPPS is good protected.
Galletto 2012 v54 full with JTAG and Mini available
Big Stars never dies:
Colin McRae (1968 ***8211; 2007)
Richard Burns (1971 ***8211; 2005)
Georg Plasa (1960 - 2011
Same reason why there is no good VCDS 10.6 clone with FT232RL inside which is working with unmodified original software in USB mode.
Same thing with MPPS. I know reason, but don't know how to solve it.
too much and software solution is shitty if you ask me, it is somehow risky because bugs of cracking.
i have updated mine with new mcu and for lower price then this above and i can download latest soft from official page - currently 5.0.1.10 workinghow long it will last i dont know but till now working perfekt and it is more secure solution for working since it is like original no cracks
Hmm..that sounds interesting. I have also mpps Polish clone and will test it soon..this MCU update sounds interesting. Tell me more.
sorry no advertising on public forum, that's the forum rules, but in private msg i can give you the link for the mcu.
regards
link for version 5.0.1.10?
Hi!
Need help!
I made update to 5.0.1.10 official version.Got error no external voltage found.
You are lucky winner. You can order new mpps or buy some mcu with working previous fw,you cannot go back to older sw version.
Nobody sayd you can update every mpps to 5.x without having issues.
By reading the threT you should see,update to 5 requires new mcu or cracked installer,but this installer u wont find it free on net.
can be programmed directly into the tool the MCU,
depends on you which version do you want!
atb
hello.
i have also this mpps 3.0.2.37.
i tried to read a4 1,8t year 2002 (29f800,1024kb) via obd.
it seems that the file is compressed or coded it only has 317kb. i have no idea whats happened here, i tried it several times, always the sam problem.
i have attached the file.
does anyone have a solution for that?
your interface MPPS is black list.
but you can find full dump into the memory computer.
before save to file , open winhex, open ram, open process mpps, open primary memory and find star your dump.
end dumps will be : xxxxxxxx+000FFFFF
copy and past to a new file and save it.
it can make to MPPS 5.0.10 too!
Tereks
that looks more like a tiny copy protection of you tune in the ECU?!
stating "NOREAD"
search for it or look here:
http://www.digital-kaos.co.uk/forums...tml#post863893
Someone had tested vw edc17 cp14 with mpps ?
possible or no?
thx
EngineGen is a robber : Dmitry Tolmachev !!!!! Be careful guys !!! this guy sucked me 180 euros ....
