Page 89 of 243 FirstFirst ... 3979848586878889909192939499139189 ... LastLast
Results 1,321 to 1,335 of 3633
Thread: MPPS
  1. #1321
    DK Veteran Amine13's Avatar
    did you read some ecus with the new version, even when it's recognized as clone ?!
    Just start, and all come itself!!!!!!!
  2. #1322
    pt
    i read only a edc15p
  3. #1323
    Quote Originally Posted by zecas View Post
    hi
    i have a clone that is working with v4 at the dirst time i try to upgrade it the soft reconized the HD but i always got ecu not found today i try again and fore my surprise it is working even when the SW reconize it as an clone.
    strange or not
    data is 24/12/2011 why?
  4. #1324
    is the one with aluminium box with super chit etc... writting on it
    regards
    show a screenshot with serial number, no delate
  5. #1325
    Spain
    Know if there is any type Mprog reading program of the MPPS Sislabs.
    Sorry for my English
  6. #1326
    Moon
    Silicon labs c8051f340 MCU is protected ... if that was your question.
  7. #1327
    ITA
    Quote Originally Posted by bazare View Post
    New update with some surprises
    hyunday edc 16
    kia edc 16
    bmw 3.5d edc16
    bmw Edc16 3.5 what is?
    i have a 535d 2006 edc16c35 but is 3000cc ..
    3.5 what is a new model?
  8. #1328
    Where i can found soft cloned mpps, i have now 3.0.2.19
    I want change 3.0.2.37 version
    I have 41323234 sn and v 4.03
    Obd model like this:
  9. #1329
    Moon
    there is no cracked version for mpps sw only genuine that work with cloned interface
  10. #1330
    hi
    strange or not
    That makes it easy to find the right thing to patch on SW.
    Now we got to look for what triggers that text to show up "Unit is a clone" and then do a JMP and it won't detect it a s a clone anymore.
  11. #1331
    I find nefmoto software so much better than MPPS to read and flash ME7 though. You guys are crazy if you use MPPS for ME7.
    Nefmoto will read without pulling fuse!
  12. #1332
    Default mpps v5.0.1.2 clone
    1 problem not caculate checksum for new version v5.0.1.2
    How do I fix checksum
  13. #1333
    Slovenia
    Is there a fault in MPPS 3.0.2.37 ECU list?
    Volkswagen Golf (or any other VAG) lists 1.9 TDI EDC16U1 and 1.9 TDI EDC16U34. But then there is 2.0 TDI EDC16C31.
    I'm almost sure that 1.9 TDI should be either U1 or U31, and not U34.
    I played with Golf 2007 1.9 TDI 90HP, I read the ECU using all three options. It read the ECU without any problems no matter which ECU I selected. And the file was always 2MB in size, data inside were also OK and the same in all three files.
    Since it is a 2MB file I guess it cant be EDC16U1 right?
    For writing I chose 1.9 TDI EDC16U34 and it wrote the file OK. But it stopped at the 49% with "Checksum not calculated" and then followed by "turn off the key". After that car started OK, I read the ECU again and modified file was written OK. So whats the deal here?
  14. #1334
    Quote Originally Posted by TribesMac View Post
    no fault i think
    mpps switch automatic to right ECU Type. So if you have U31/4 and you will read it with U1 ... mpps software switch to U31/4 and read 2MB.
    But the 2MB file is only a 512KB read ... all other is FF .. not same as CMD !!
    But also CMD 2MB files work with mpps. So you can flash cmd files with mpps.
    But i am not sure if you can to mpps files write with cmd (because at the beginnig of the File only FF FF ... ) ???
  15. #1335
    Slovenia
    Yes MPPS makes a partial read.
    Good to know there is a automatic switching. A bit of fail-safe never hurts
    Now the only thing that is bothering me is what happened at 49%... :/
