Page 43 of 243 FirstFirst ... 3338394041424344454647485393143 ... LastLast
Results 631 to 645 of 3633
Thread: MPPS
  1. #631
    ipejasinovic's Avatar
    Jun 2009
    Bosnia & Herzegovina
    As I know, Viaken's version can't do EDC16 on BMW's, because faulty hardware.
    Galletto 2012 v54 full with JTAG and Mini available
    Big Stars never dies:
    Colin McRae (1968 ***8211; 2007)
    Richard Burns (1971 ***8211; 2005)
    Georg Plasa (1960 - 2011
  2. #632
    May 2010
    Moon
    viaken is 1.0.0.x or 3.0.2.37 ?
  3. #633
    exxl's Avatar
    Jun 2009
    Bosnia-Herzegowina, Bos. Krupa
    they have now 3.0.2.37 but its same unstable shit like the 1.0.0.x because its same hardware
    and if anyone reads these thread couple of pages before could see that this hw that viaken sells has a mistake on pcb a slightly mistake on pcb but a big for the work.
    with bmw edc16 and viaken hardware you got to be lucky to read even the id
  4. #634
    Jun 2009
    @bazare
    Is his V3 still in Alu box? If Yes, then V3 also has same problems...
  5. #635
    Jul 2009
    Berks, UK
    I got one V3 lead with kulled by update. Shows Error 12 and serial is FFFFFFFF.
    Can anyone supply programmed MCU for it? had no problem doing BMW and thts the main reason i bought it. Seller never told me it's unsafe to install the new version so i used it and now it'ds fxxxd up.
  6. #636
    Nov 2009
    Quote Originally Posted by gzk View Post
    sorry i forgot the file
    i got same dump files size from A4 1.9 TDI ED16, the .bin also starts with No read file has been encrypted .. i can't figure out, what's the problem .. maybe a locked no read ecu by a chiptuner? is that bmw 330d E90 modded?
  7. #637
    May 2010
    Moon
    Quote Originally Posted by etronic2 View Post
    You either send it back to be reprogramed or throw it in the garbage can.
  8. #638
    Sep 2010
    Quote Originally Posted by gdanx View Post
    yes it is
    the owner want to get is car back to stock and the shiftec seller don't want ....
    i just open the bin file and i can see the no read header , so i think it's like you said blocked by shiftec .
    i will try another stock bmw to check the new viaken cable and report .
  9. #639
    Sep 2010
    i just make some test on the mpps soft, but didn't try with my clone cable plugged , need your advice before
    i have installe latest version of the soft .
    backup the 3 directory \check \database \drive
    after i uninstall it and reinstall the 3.0.2.37 soft (the one that not kill the clone )
    i replace the directory by the one from latest version i do the backup .
    launch the soft and voila , have the same car list than the latest version but on the old soft .
    so if the routine that kill the cable is on the EXE , perhaps you will be able to have the latest car without kill your clone .
    i'm havent the knowlegde to do more and don't want to risk my clone .
    just my 2 cents
    sorry for my english ...
  10. #640
    Jun 2009
    Doesn't work. MPPS.exe has some check on all crucial files inside that distribution and if you just change one byte, he won't work.
  11. #641
    Top Poster naruto12's Avatar
    Jan 2010
    Portugal
    Hi there friends, iam having an error on my mpps, error1, in driver definations my driver flash apeer yelow, , can anyone tell me the reason for that?or wow im gonna resolve it?.
    I dont actualize my mpps for new version...
    Regards
  12. #642
    Jun 2009
    just my 2 cents
    doesn't work because the new soft make hardware update
    this update kills the clones, and without update the interface
    was not find by soft
  13. #643
    Nov 2009
    yes it is
    yes, same here, that audi was also modded, so it's all clear now .. if an ecu has NO READ protection, MPPS can't read out the flash properly .. funny thing is that i was able to read out the bin with 20 USD galleto clone without any problems .. maybe MPPS is able to read it, but AMT cartech has disabled this feature
  14. #644
    DK Veteran rsibiza's Avatar
    For sure...coz there is existing a patch for noread on mpps...
    But until today his engineer didnt release it yet..
  15. #645
    Sep 2010
    Quote Originally Posted by dodgeripper View Post
    i understand , that's the reason i propose to not use the new EXE .
